As many popular media players, such as PSP, Zune, Xbox, and Pocket PC, can paly WMV file, it become more and more popular nowadays. However, not all the available videos are WMV file, so we need to convert them. This guide aims to show you how to convert videos to WMV file on Windows.
To convert videos to WMV file you need Aiseesoft
WMV Converter.
Step 1: Load Video
You can easily load your video by clicking “Add File” and find the video that you want to convert to WMV format.
Step 2: Output Profile and Settings
This powerful WMV converter provides you many profiles according to what devices you have or you just need the general WMV video.
Click “Profile” drop-down list and choose one output profile according to your need.
You can also specify the settings of the output video: you can adjust the video/audio encoder/Bitrate; Channel; Frame Rate; and Resolution.
Step 3: Video Editing and Conversion
Before you start your conversion you can editing your video with this powerful video converter.
1. Effect:
You can adjust the “Brightness”, “Contrast” and “Saturation” of your output video by dragging the bar on each of the section.
You are also allowed to use “deinterlacing” function to improve your effect of your output video.
2. Trim:
Using trim function you can remove the part that you don't want to convert and pick up any part of the video to convert.
Three ways to do that:
a. You can drag the buttons to set the start and end time
b. You can preview the video first and when you want to start trim click the left one of the pair buttons when you want to end click the right one.
c. You can set the exact start and end time at the buttom of the pop-up window.
3. Crop:
Crop function allows you to choose any play area to convert.
Two ways to do that:
a. You can set your own mode on the bottom of the pop-up window
b. You can drag frame to set your own crop mode
After editing your output video, you can click “Start” to begin your conversion.
If you don't want to edit your video, you can directly start your conversion.
WMV Converter.
Step 1: Load Video
1. Effect:
2. Trim:
3. Crop:
