AMD Readying Radeon HD 4790 Based on RV790
AMD is preparing yet another performance-mainstream Radeon HD 4000 series SKU. The Radeon HD 4790 finds lineage from the Radeon HD 4890, currently AMD's fastest GPU. The RV790 GPU will be given a new set of specifications and memory configuration, to yield an SKU that performs better than the Radeon HD 4770, and slightly better than HD 4850. It beats us as to why it is positioned in the HD 4700 series, and not say "Radeon HD 4860", but we are too late to comment on that.
Specifications-wise, the RV790 core runs at 600 MHz, slightly lower than the RV770 in Radeon HD 4850 (625 MHz), but its performance increment over it comes from the use of GDDR5 memory. The GPU makes use of a 256-bit wide GDDR5 memory interface. It handles 512 MB of memory clocked at 800 MHz (3200 MHz effective). Being based on the RV790, it is pin-compatible with any existing HD 4890 PCB. Price-wise, it is expected to sit between the HD 4850 and HD 4870.
จาก techpowerup.com ครับ
เป็นดั่งคาด ตระกูล 4700 มันต้องมีภาคต่อ RV790
ซับไทยไม่มีครับ ไม่เป็น _________________
