The Best In Thailand
  • The Best In Thailand
    Koolance 62 Line items
    1/Lamptron Black Aluminum FC-2 Fan Controller - 45 watts / 6 Channels
    1/Aquaero 4.00 USB Fan-Controller, black/white
    1/Black Faceplate for Aquaero
    2 /Aqua Computer Poweradjust USB (with mounting kit)
    1/Aquatube G1/4 Delrin black with fittings
    1/Black Faceplate for Aquatube
    1/ aquabay AT (installation bay for aquatube
    2/ UN Designs Z-Bracket for 3G or Absolute Pump Brackets
    9/ Blacknoise Noiseblocker Multiframe S-Series M12-S1 51.2 CFM
    1/ Logisys Dual White 12in. CCFL Light kit
    1/ Noise Isolator PSU Vibration Dampener Kit - Black
    1/ Noise Isolator 3.5" Hard Drive Silicon Rubber Protective Skin
    2/ Hard Drive Vibration Absorber for 3.5in. Drives
    2/ SATA II Cable Black 24" 180 to 90 degree connector
    1 /TIM-Consultants - T-C Grease™ 0098 Thermal Interface Material
    1 /Floppy Black 18"
    1/ Bitspower Rad Support
    1/ Swiftech MCB-120 Rev 2 Radbox Radiator/fan housing - Black
    2 / Feser One F1 Cooling Fluid - UV Black - 1 Liter
    1/ Lian li 5.25 inch Black Dvd Rom front cover
    3/ Lian li 5.95 Color = Black Mesh cover
    2/ DD12V-D5 Pump Variable Speed by Laing
    2 /Feser X-Changer QUAD 480 Extreme Performance Radiator
    8/ Feser TFC Xtender - Radiator Shroud 120 - BLUE LED
    2/A.C. Ryan AcrylPanel 3mm 480x480mm Black
    Black Heatshrink 1/2 inch - 5 foot $
    Custom Cut Length 3/8 Expandable Sleeving - 10 foot
    Tygon R3603 7/16 x 5/8" AAC00033 28 Foot
    also the Koolance Blocks are as followed
    2/ VID-NX295
    6/ RAM-35,
    1 CHC-120-V06
    1 CHC-122
    1 CPU-340
    2 MVR-40
    gpu
    STILL MORE TODO WITHIN THE NEXT FEW WEEKS DONE
      ทำบล๊อคน้ำเองเหรอครับ หรือว่าอะไรเห็นถ่ายรูปทั่วไปหมด-*-
        jing lor not at 200.000 no one have for sure this is the best stuff on the market what i have but some on the below will be changed because have water kit hint the v8
        CPU
        i7 920 3.7 GHZ
        Motherboard Asus P6T DE
        Memory Ocz 12/1600 Triple Channel DDR3
        Graphics Card GF 295 SLI
        Hard Drive
        Seagate 1TB Sound Card
        SB X-Fi Titanium Fatal1ty Champion Serie
        Power SupplyThermalTake ToughPower 1200
        CPU cooling CM V8
        OS Vista Ultimate 64bit
        Monitor Samsung 23" 2333SW
          แล้วติดเข้าไปยังไงอ่า *-*
            Incredible!!!
            Where did you get water block for GTX 295 ???
              สรวงสวรรค์ของนักเล่นคอมพ์จริงๆ
              แต่ว่าถ้ามันมี เม้าแบบ wii mote ก็ดีนะ
              มีตัวรับ เวลาจะคลิ๊กก็ยิง รีโมทไปที่จอเลย ต้องการจะเข้าอะไรก็ง่ายดาย
              แต่ว่ามันรึยังง่ะแบบนี้
                ขอเสียงภาษาไทยโดยพันธมิตรด่วนครับ ผมจบภาษาอังกฤษมายังไม่เข้าใจเลย หรือว่านี่เป็นภาษาคอมพิวเตอร์ครับ แฮ่ะๆ^^
                  i got them from the usa pang mak mak also had to pay duty and tax and shipping
                  but you can get them from Koolance at 6200bth each also have to buy nozzels and all the other extras
                    just for all the Koolance stuff mosfit nth sth cpu gpu nozzels 30,000 bht
                      Where's your home?
                      I will steal your PC....ha ha ha
                        lol, you are so funny.
                          lol 1. security guard 2 steal cage aound the windows and door , 3 dogs ,4 me lol no chance
                            This Is a book
                              Originally posted by TikkyMix View Post
                              This Is a book
                              เนียน
