ไม่รู้เคยมีใครโพสรึยังนะ
OCWorkbench has found some pictures and specs of NVIDIA's mainstream DirectX 10 cards, the 8600GT and the 8600GTS. The GT (pictured below on the left) is the replacement for the 7600GT and will feature the G84-300 GPU running at 540MHz and either 128MB or 256MB of 128-bit GDDR3 RAM at 1400MHz, priced between $150 and $180. The 8600GTS (below on the right) is a step up from the
GT and will replace the 7900GS, using the G84-400 GPU running at 675MHz and either 256MB or 512MB of 128-bit GDDR3 RAM at 2000MHz, with a price of between $200 and $250. As reported before on techPowerUp!, these cards should be released (along with the 8500GT) on April 17th.
เครดิต techpowerup ! และ ocworkbench
8600GT
8600GTS
w
8600GT
8600GTS
w
ก็ถูกแล้วนิ 8600GTS ต้งเสียบไฟเพิ่ม
