Geforce ForceWare 181.00 มาแล้วว เทสกันหน่อยซิ
  • Geforce ForceWare 181.00 มาแล้วว เทสกันหน่อยซิ
    Geforce ForceWare 181.00 Win XP 32-bit
    On this page you can download Geforce ForceWare 181.00 Win XP 32-bit.
    Version: 181.00
    Publisher: NVIDIA
    Date added: 2008-12-19 02:00:11
    File Size: 60 MB
    OS Support: Windows XP 32-bit
    License: Freeware
    Downloads: 3709 downloads
    Software type: Videocards - NVIDIA GeForce (XP 32-bit)
    Scan Computer for driver updates
    You are here: Guru3D.com » downloads » category selection » Geforce ForceWare 181.00 Win XP 32-bit
    Software Description
    Download Geforce ForceWare 181.00 for Windows XP 32-bit
    NVIDIA is distributing a new revision GeForce driver. First off, this is a developer driver, mainly showing OpenGL 3.0 support. Though it should work fine for the cards supported, this is not a final driver.
    The driver has full support for OpenGL 3.0 and version 1.3 of the OpenGL shading language (GLSL).
    The drivers work on Geforce 8 or newer graphics cards along with a number of Quadro professional offerings. According to Nvidia, these drivers allow developers to "immediately begin using these drivers to build OpenGL 3.0 functionality into their software to give end-users new, superior graphics reproduction and visualization features."
    We have a discussion thread open on this driver right here.
    You need one of the following graphics cards to get access to the OpenGL 3.0 and GLSL 1.30 functionality:
    Desktop
    Quadro FX 370, 570, 1700, 3700, 4600, 4700x2, 4800, 5600, 5800, Quadro VX200, Quadro CX
    GeForce 8000 series or higher; GeForce GTX 260, 280
    Notebook
    Quadro FX 360M, 370M, 570M, 770M, 1600M, 1700M, 2700M, 3600M, 3700M
    This driver implements all of GLSL 1.30 and all of OpenGL 3.0 and exposes the following new extensions:
    OpenGL 2.1 extensions:
    ARB_vertex_array_object
    ARB_framebuffer_object
    ARB_half_float_vertex
    OpenGL 3.0 extensions:
    WGL_create_context
    GLX_create_context
    ARB_draw_instanced
    ARB_geometry_shader4
    ARB_texture_buffer_object
    Download http://downloads.guru3d.com/Geforce-...load-2145.html
    ลองเทสแล้ว GTA IV ลื่นขึ้นครับเฟรมเพิ่มมาประมาณ 5-9 เฟรม แถมคงที่ด้วย ของผมสเปกตามลายเซนต์ เฟรม 30 up ครับ แจ่มมากๆเลยครับแล้วท่านอื่นเป็นไงกันบ้าง
    Driver แจ่มครับ
      แน่ใจนะ จะได้ลองลง
        แน่ดิครับผมเล่นเฟรมประมาณ 34 ครับ
          จัดไปครับ เพิ่งเห็นเหมือนกัน กำลังจะมาดู FeedBack ในนี้เลย อิอิ
          เด๋วลองก่อน
            เห็นคนใช้ driver 181 นี้เล่น dead space แล้วภาพแตก
              http://forums.overclockzone.com/foru...d.php?t=355119
              ผมไม่ได้ใช้ 8800 เลยไม่เป็นครับ อิอิ ที่สำคัญ GTA IV เฟรมคงที่ !!!!
                เดี่ยวลองมั่ง แต่ไม่มีเกม GTA IV เฮะ เดี่ยวลองโหลดบิตมาเล่นดีกว่า
                  เล่น GTA จบแล้ว
                  ลงปุ๊บ Left 4 Dead เน่าแบบ 180 ก่อนหน้าเลยไปใช้ 178 เหมือนเดิม
                    งงเล่นแล้วภาพแตกไม่ก็หลุด เหอๆ - -a
                      ใช้เวอร์ชั่น 178.24 เสถียรที่สุดครับ สำหรับ GeForce serie 9 ผมลองใช้เวอร์ชั่นที่ใหม่กว่า2-3รุ่น แย่มาก เล่นเกมออนไลน์บางเกม เด้งหลุด ภาพเม็ดสี แตกก็มี
                        181.00 เล่นกับ crysis ก็โอเคนะ ไม่ต่างจาก version แต่เกมอื่นไม่รู้นะครับ
                          ต้องลอง
                            ต้องลอง
                              ต้องลุ้น
