7950 GX2 XFX ผมปกติป่าวท่าน
  • 7950 GX2 XFX ผมปกติป่าวท่าน
    4200+@ 2.5 G
    Abit KN9 SLI
    Ram 3 GIG ไหงใด้แค่นี้หรือบอดไม่รองรับ????????????????????? 3D mark 8000 กว่า งง ปกติป่าววิ่งแค่ 8X ช้วยที
    File Name
    Benchmark
    Version 1.1.0
    Width 1024
    Height 768
    Anti-Aliasing None
    Anti-Aliasing Quality 0
    Texture Filtering Optimal
    Anisotropic Level 1
    VS Profile 3_0
    PS Profile 3_0
    Force full precision No
    Disable HW shadow mapping No
    Disable post-processing No
    Force software vertex shader No
    Color mipmaps No
    Force software FP filtering No
    Repeat tests Off
    Fixed framerate Off
    3DMark Score 8070 3DMarks
    SM2.0 Score 3680
    HDR/SM3.0 Score 3854
    CPU Score 1782
    Game Score N/A N/A
    GT1 - Return To Proxycon 29.508 FPS SM2.0 Graphics Tests
    GT2 - Firefly Forest 31.832 FPS SM2.0 Graphics Tests
    CPU1 - Red Valley 0.568 FPS CPU Tests
    CPU2 - Red Valley 0.894 FPS CPU Tests
    HDR1 - Canyon Flight 37.702 FPS HDR/SM3.0 Graphics Tests
    HDR2 - Deep Freeze 39.379 FPS HDR/SM3.0 Graphics Tests
    Fill Rate - Single-Texturing 0.000 N/A N/A Feature Tests
    Fill Rate - Multi-Texturing 0.000 N/A N/A Feature Tests
    Pixel Shader 0.000 N/A N/A Feature Tests
    Vertex Shader - Simple 0.000 N/A N/A Feature Tests
    Vertex Shader - Complex 0.000 N/A N/A Feature Tests
    Shader Particles (SM3.0) 0.000 N/A N/A Feature Tests
    Perlin Noise (SM3.0) 0.000 N/A N/A Feature Tests
    8 Triangles 0.000 N/A N/A Batch Size Tests
    32 Triangles 0.000 N/A N/A Batch Size Tests
    128 Triangles 0.000 N/A N/A Batch Size Tests
    512 Triangles 0.000 N/A N/A Batch Size Tests
    2048 Triangles 0.000 N/A N/A Batch Size Tests
    32768 Triangles 0.000 N/A N/A Batch Size Tests
    System Info
    Version 3.12
    CPU Info
    Physical Processors 1
    Logical Processors 2
    Central Processing Units
    Manufacturer AMD
    Family AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
    Architecture 64-bit
    Internal Clock 2508 MHz
    Internal Clock Maximum 2509 MHz
    External Clock 228 MHz
    Socket Designation Socket AM2
    Type
    Upgrade Socket 940
    MultiCore 2 Processor Cores
    HyperThreadingTechnology N/A
    Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, PAE, NX
    Version AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
    Caches Level Capacity Type Type Details Error Correction Type Associativity
    1 128 KB Internal Synchronous
    2 512 KB Internal Synchronous
    CPUIDs EAX EBX ECX EDX Order
    0x00000001 0x68747541 0x444d4163 0x69746e65 0
    0x00040fb2 0x00020800 0x00002001 0x178bfbff 1
    Ext CPUIDs EAX EBX ECX EDX Order
    0x80000018 0x68747541 0x444d4163 0x69746e65 0
    0x00040fb2 0x000008d1 0x0000001f 0xebd3fbff 1
    0x20444d41 0x6c687441 0x74286e6f 0x3620296d 2
    0x32582034 0x61754420 0x6f43206c 0x50206572 3
    0x65636f72 0x726f7373 0x30323420 0x00002b30 4
    0xff08ff08 0xff20ff20 0x40020140 0x40020140 5
    0x00000000 0x42004200 0x02008140 0x00000000 6
    0x00000000 0x00000000 0x00000000 0x0000003f 7
    0x00003028 0x00000000 0x00000001 0x00000000 8
    0x00000000 0x00000000 0x00000000 0x00000000 9
    0x00000001 0x00000040 0x00000000 0x00000000 10
    0x00000000 0x00000000 0x00000000 0x00000000 11
    0x00000000 0x00000000 0x00000000 0x00000000 12
    0x00000000 0x00000000 0x00000000 0x00000000 13
    0x00000000 0x00000000 0x00000000 0x00000000 14
    0x00000000 0x00000000 0x00000000 0x00000000 15
    DirectX Info
    Version 9.0c
    Long Version 4.09.00.0904
    DirectDraw Info
    Version 5.03.2600.5512
    Primary Device NVIDIA GeForce 7950 GX2
    Linked Display Adapters TRUE
    Display Devices
    Display Device
    Description NVIDIA GeForce 7950 GX2
    Manufacturer NVIDIA
    Total Local Video Memory 1024 MB
    Total Local Texture Memory 690 MB
    AGP Aperture Size 0 B
    Driver File nv4_disp.dll
    Driver Version 9.1.4.7
    Driver Details
    Driver Date 11/8/2006
    Driver WHQL Certified TRUE
    Max Texture Width 4096 px
    Max Texture Height 4096 px
    Max User Clipping Planes 6
    Max Active Hardware Lights 8
    Max Texture Blending Stages 8
    Fixed Function Textures In Single Pass 8
    Vertex Shader Version 3
    Pixel Shader Version 3
    Max Vertex Blend Matrices 0
    Max Texture Coordinates 8
    PCI
    Name NVIDIA GeForce 7950 GX2
    Vendor ID 0x10de
    Device ID 0x0294
    SubSystem ID 0x22141682
    Revision ID 0x00a1
    Bus
    Type PCI Express
    Revision 1
    Enabled TRUE
    Rate 8
    Sideband Addressing Not Supported
    Fast Write Not Supported
    Texture Formats
    32-bit ARGB [8888]
    32-bit RGB [888]
    16-bit RGB [565]
    16-bit RGB [555]
    16-bit ARGB [1555]
    16-bit ARGB [4444]
    8-bit A [8]
    8-bit YUV [800]
    16-bit AYUV [8800]
    FourCC [DXT1]
    FourCC [DXT2]
    FourCC [DXT3]
    FourCC [DXT4]
    FourCC [DXT5]
    Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
    VGA Memory Clock 601 MHz
    VGA Core Clock 500 MHz
    Max VGA Memory Clock 0 Hz
    Max VGA Core Clock 0 Hz
    DirectShow Info
    Version 6.05.2600.5512
    Registered DirectShow Filters
    .RAM file Parser
    AC3 Parser Filter
    AC3File
    ACELP.net Sipro Lab Audio Decoder
    ACM Wrapper
    ASF ACM Handler
    ASF DIB Handler
    ASF DJPEG Handler
    ASF ICM Handler
    ASF JPEG Handler
    ASF URL Handler
    ASF embedded stuff Handler
    ASX file Parser
    ASX v.2 file Parser
    AVI Decompressor
    AVI Draw
    AVI Splitter
    AVI/WAV File Source
    Avi Source
    Avi Splitter
    Color Space Converter
    CyberLink Audio Decoder
    CyberLink AudioCD Filter (PDVD6)
    CyberLink DVD Navigator (PDVD6)
    CyberLink Video/SP Decoder
    DC-Bass Source
    DV Muxer
    DV Splitter
    DV V/A ACM Source Filter
    DV V/A Source Filter
    DV Video Decoder
    DV Video Source Filter
    Decrypt/Tag
    Default DirectSound Device
    Default MidiOut Device
    DirectVobSub (auto-loading version)
    DivX Decoder Filter
    FLV Source
    FLV Splitter
    FLV4 Video Decoder
    File Source (Async.)
    File Source (Netshow URL)
    File Source (URL)
    File stream renderer
    Indeo? audio software
    Indeo? video 4.4 Decompression Filter
    Indeo? video 5.10 Decompression Filter
    InterVideo AAC (XForm) Decoder
    InterVideo Audio Decoder
    InterVideo MPEG4 Video Decoder
    InterVideo Video Decoder
    Internal Script Command Renderer
    Line 21 Decoder
    Line 21 Decoder 2
    MIDI Parser
    MJPEG Decompressor
    MP4 Source
    MP4 Splitter
    MPEG Audio Decoder
    MPEG Layer-3 Decoder
    MPEG Video Decoder
    MPEG-2 Demultiplexer
    MPEG-2 Sections and Tables
    MPEG-2 Splitter
    MPEG-I Stream Splitter
    MPEG4 Video Source
    MPEG4 Video Splitter
    Microsoft MPEG-4 Video Decompressor
    Microsoft Screen Video Decompressor
    Mpeg Splitter
    Multi-file Parser
    NSC file Parser
    Nero DVD Decoder
    Nero DVD Navigator
    Nero Digital Audio Decoder
    Nero Digital Parser
    Nero ES Video Reader
    Nero File Source (Async.)
    Nero QuickTime(tm) Audio Decoder
    Nero QuickTime(tm) Video Decoder
    Nero Vcd Navigator
    Nero Video Decoder
    Ogg Multiplexer
    Ogg Splitter
    Overlay Mixer2
    QT Decompressor
    QuickTime Movie Parser
    RadLight MPC DirectShow Filter
    RealAudio Decoder
    RealMedia Source
    RealMedia Splitter
    RealVideo Decoder
    SAMI (CC) Parser
    ULead File Source (Async.)
    Ulead DVD Video decoder 2
    Ulead MPEG Audio Decoder
    Ulead MPEG Splitter
    Ulead MPEG Video Decoder
    Ulead Ogg Parser
    Ulead OggVorbis Decoder
    Ulead OggVorbis Encoder
    VBI Surface Allocator
    VGA 16 Color Ditherer
    VP6 Decompressor
    VP7 Decompressor
    Video Port Manager
    Video Renderer
    Vorbis Decoder
    WM ASF Reader
    WM ASF Writer
    WST Decoder
    WavPack Audio Decoder
    WavPack Audio Splitter
    Wave Parser
    Windows Media Audio Decoder
    Windows Media Multiplexer
    Windows Media Update Filter
    Windows Media Video Decoder
    Windows Media source filter
    XML Playlist
    ffdshow Audio Decoder
    ffdshow Video Decoder
    madFlac Decoder
    madFlac Source
    DirectSound Info
    Version 5.3.2600.5512
    Speaker Configuration Stereo
    Speaker Geometry Wide
    Primary Device Realtek HD Audio output
    Sound Devices
    Sound Device
    Description Realtek HD Audio output
    Manufacturer Realtek
    Driver File RtkHDAud.sys
    Driver Version 5.10.0.5717
    Driver Date 13/10/2008
    Max Supported 3D Hardware Sounds 33
    PCI
    Name Realtek High Definition Audio
    Vendor ID 0x0000
    Device ID 0x0000
    SubSystem ID 0x00000000
    Revision ID 0x0000
    Capabilities Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
    HD Audio Support TRUE
    EAX Support Supported
    Memory Info
    Total Physical Memory 3072 MB
    Free Physical Memory 2605 MB
    Total Pagefile Memory 5 GB
    Free Pagefile Memory 4628 MB
    Memory Arrays
    Memory Array
    Max Module Capacity 16 MB
    Location System Board
    Use System
    Supported Error DC
    Supported Speeds
    Supported Types
    Supported Voltages
    Memory Slots Installed Enabled Size Form Factor Frequency Slot Manufacturer Type Type Details Enabled Size Total Bit Width Data Bit Width
    1024 MB DIMM 0 Hz A0 [Bank0/1] None 1024 MB 64 b 64 b
    1024 MB DIMM 0 Hz A1 [Bank2/3] None 1024 MB 64 b 64 b
    512 MB DIMM 0 Hz A2 [Bank4/5] None 512 MB 64 b 64 b
    512 MB DIMM 0 Hz A3 [Bank6/7] None 512 MB 64 b 64 b
    Motherboard Info
    Supported Slot Types ISA, PCI, PCI Express
    Manufacturer http://www.abit.com.tw/
    Model KN9(NF-MCP55 series)
    Version 1.x
    BIOS Vendor Phoenix Technologies, LTD
    BIOS Version 6.00 PG
    BIOS Release Date 27/2/2007
    BIOS Properties Plug and Play, Flash
    Card Slots Order Designation Type Characteristics Data Bus Width Details Device Class Manufacturer Driver File Driver Version Driver Date Name Vendor ID Device ID SubSystem ID Revision ID IRQ
    1 PCI0 PCI 5.0V, PME Signal 32 b Available, Long 0x0000 0x0000 0x00000000 0x0000
    2 PCI1 PCI 5.0V, PME Signal 32 b Available, Long 0x0000 0x0000 0x00000000 0x0000
    3 PCI2 PCI 5.0V, PME Signal 32 b In Use, Long 0x0000 0x0000 0x00000000 0x0000
    4 PCI3 PCI Express 5.0V, PME Signal 32 b In Use, Long 0x0000 0x0000 0x00000000 0x0000
    5 PCI4 PCI Express 5.0V, PME Signal 32 b In Use, Long 0x0000 0x0000 0x00000000 0x0000
    6 PCI5 PCI Express 5.0V, PME Signal 32 b In Use, Long 0x0000 0x0000 0x00000000 0x0000
    7 PCI6 PCI Express 5.0V, PME Signal 32 b In Use, Long 0x0000 0x0000 0x00000000 0x0000
    PCI Devices Manufacturer Location Type Name Vendor ID Device ID SubSystem ID Revision ID
    (Standard system devices) PCI bus 0, device 24, function 0 PCI standard host CPU bridge 0x1022 0x1100 0x00000000 0x0000
    (Standard system devices) PCI bus 0, device 24, function 1 PCI standard host CPU bridge 0x1022 0x1101 0x00000000 0x0000
    (Standard system devices) PCI bus 0, device 24, function 2 PCI standard host CPU bridge 0x1022 0x1102 0x00000000 0x0000
    (Standard system devices) PCI bus 0, device 24, function 3 PCI standard host CPU bridge 0x1022 0x1103 0x00000000 0x0000
    Texas Instruments PCI bus 1, device 8, function 0 Texas Instruments OHCI Compliant IEEE 1394 Host Controller 0x104c 0x8023 0x1c20147b 0x0000
    (Standard system devices) PCI bus 6, device 0, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x01b3 0x00000000 0x00a3
    (Standard system devices) PCI bus 7, device 0, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x01b3 0x00000000 0x00a3
    (Standard system devices) PCI bus 7, device 1, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x01b3 0x00000000 0x00a3
    NVIDIA PCI bus 9, device 0, function 0 NVIDIA GeForce 7950 GX2 0x10de 0x0294 0x22141682 0x00a1
    NVIDIA PCI bus 8, device 0, function 0 NVIDIA GeForce 7950 GX2 0x10de 0x0294 0x22141682 0x00a1
    (Standard system devices) PCI bus 0, device 1, function 0 PCI standard ISA bridge 0x10de 0x0360 0x00000000 0x00a2
    NVIDIA PCI bus 0, device 1, function 1 NVIDIA nForce PCI System Management 0x10de 0x0368 0x1c20147b 0x00a2
    (Standard system devices) PCI bus 0, device 0, function 0 PCI standard RAM Controller 0x10de 0x0369 0x1c20147b 0x00a1
    (Standard system devices) PCI bus 0, device 1, function 2 PCI standard RAM Controller 0x10de 0x036a 0x1c20147b 0x00a2
    (Standard USB Host Controller) PCI bus 0, device 2, function 0 Standard OpenHCD USB Host Controller 0x10de 0x036c 0x1c20147b 0x00a1
    (Standard USB Host Controller) PCI bus 0, device 2, function 1 Standard Enhanced PCI to USB Host Controller 0x10de 0x036d 0x1c20147b 0x00a2
    (Standard IDE ATA/ATAPI controllers) PCI bus 0, device 4, function 0 Standard Dual Channel PCI IDE Controller 0x10de 0x036e 0x1c20147b 0x00a1
    (Standard system devices) PCI bus 0, device 6, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x0370 0x00000000 0x00a2
    Microsoft PCI bus 0, device 6, function 1 Microsoft UAA Bus Driver for High Definition Audio 0x10de 0x0371 0x1c20147b 0x00a2
    NVIDIA PCI bus 0, device 8, function 0 NVIDIA Network Bus Enumerator 0x10de 0x0373 0x1c20147b 0x00a2
    (Standard system devices) PCI bus 0, device 12, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x0374 0x00000000 0x00a2
    (Standard system devices) PCI bus 0, device 14, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x0375 0x00000000 0x00a2
    (Standard system devices) PCI bus 0, device 10, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x0376 0x00000000 0x00a2
    (Standard system devices) PCI bus 0, device 15, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x0377 0x00000000 0x00a2
    (Standard system devices) PCI bus 0, device 13, function 0 PCI standard PCI-to-PCI bridge 0x10de 0x0378 0x00000000 0x00a2
    NVIDIA Corporation PCI bus 0, device 5, function 0 NVIDIA nForce 590/570/550 Serial ATA Controller 0x10de 0x037f 0x1c20147b 0x00a2
    NVIDIA Corporation PCI bus 0, device 5, function 1 NVIDIA nForce 590/570/550 Serial ATA Controller 0x10de 0x037f 0x1c20147b 0x00a2
    NVIDIA Corporation PCI bus 0, device 5, function 2 NVIDIA nForce 590/570/550 Serial ATA Controller 0x10de 0x037f 0x1c20147b 0x00a2
    System Devices Manufacturer Name Vendor ID Device ID SubSystem ID Revision ID
    (Standard system devices) PCI standard host CPU bridge 0x1022 0x1100 0x00000000 0x0000
    (Standard system devices) PCI standard host CPU bridge 0x1022 0x1101 0x00000000 0x0000
    (Standard system devices) PCI standard host CPU bridge 0x1022 0x1102 0x00000000 0x0000
    (Standard system devices) PCI standard host CPU bridge 0x1022 0x1103 0x00000000 0x0000
    (Standard system devices) PCI standard ISA bridge 0x10de 0x0360 0x00000000 0x00a2
    NVIDIA NVIDIA nForce PCI System Management 0x10de 0x0368 0x1c20147b 0x00a2
    (Standard system devices) PCI standard RAM Controller 0x10de 0x0369 0x1c20147b 0x00a1
    (Standard system devices) PCI standard RAM Controller 0x10de 0x036a 0x1c20147b 0x00a2
    (Standard system devices) PCI standard PCI-to-PCI bridge 0x10de 0x0370 0x00000000 0x00a2
    Microsoft Microsoft UAA Bus Driver for High Definition Audio 0x10de 0x0371 0x1c20147b 0x00a2
    (Standard system devices) PCI standard PCI-to-PCI bridge 0x10de 0x0374 0x00000000 0x00a2
    (Standard system devices) PCI standard PCI-to-PCI bridge 0x10de 0x0375 0x00000000 0x00a2
    (Standard system devices) PCI standard PCI-to-PCI bridge 0x10de 0x0376 0x00000000 0x00a2
    (Standard system devices) PCI standard PCI-to-PCI bridge 0x10de 0x0377 0x00000000 0x00a2
    (Standard system devices) PCI standard PCI-to-PCI bridge 0x10de 0x0378 0x00000000 0x00a2
    AGP
    Revision
    Rate
    Available Rate 0x00000000
    Selected Rate 0x00000000
    Aperture Size 0 B
    Sideband Addressing
    EnumValue
    String
    Hex 0x00000000
    Fast Write
    EnumValue
    String
    Hex 0x00000000
    USB Devices Description Driver Date Driver Version Device Class
    USB Root Hub 1/7/2001 5.1.2600.2180 Universal Serial Bus Controller
    USB Human Interface Device 1/7/2001 5.1.2600.5512 Human Interface Device
    FireWire Devices
    FireWire Device
    Description 1394 Net Adapter
    Driver Date 1/7/2001
    Driver Version 5.1.2535.0
    Device Class Network Adapter
    Monitor Info
    Monitors
    Monitor
    Name Plug and Play Monitor
    Manufacturer (Standard monitor types)
    Max Width 1600 px
    Max Height 1200 px
    Power Supply Info
    Batteries
    Operating System Info
    Name Microsoft Windows XP
    Version 5.1.2600
    PlatformId 2
    Service Pack
    Version 3
    Name Service Pack 3
    Suite 256
    Product Type 1
    Media Center FALSE
    Windows Environment 32-bit
    DEP
    Hardware Support TRUE
    Applications Protected TRUE
    Drivers Protected TRUE
    User Option On for essential Windows programs and services only
    Locale TH
    Desktop Width 1024 px
    Desktop Height 768 px
    Desktop BPP 32 b
    Internet Explorer Version 62900.5512
    Applications
    Scanning your system configuration
    3DMark06 - Professional Edition
    Processes Name PID Memory Usage
    System Idle Process 0 28 KB
    System 4 180 KB
    smss.exe 784 412 KB
    csrss.exe 832 3744 KB
    winlogon.exe 856 6 MB
    services.exe 904 3840 KB
    lsass.exe 916 1788 KB
    svchost.exe 1072 5 MB
    svchost.exe 1132 4736 KB
    svchost.exe 1172 23 MB
    spoolsv.exe 1500 5 MB
    explorer.exe 1884 27 MB
    UnlockerAssistant.exe 220 2540 KB
    LClock.exe 232 872 KB
    PDVDServ.exe 240 3448 KB
    Vsc32Cnf.exe 276 2996 KB
    vscvol.exe 284 2708 KB
    MagicLnk.exe 300 2808 KB
    avp.exe 324 6 MB
    RTHDCPL.EXE 376 23 MB
    rundll32.exe 604 3640 KB
    ctfmon.exe 612 3616 KB
    BitComet.exe 620 21 MB
    msmsgs.exe 636 1180 KB
    WZQKPICK.EXE 664 3408 KB
    avp.exe 1336 20 MB
    nvsvc32.exe 1400 4180 KB
    PnkBstrA.exe 1744 2868 KB
    PnkBstrB.exe 1780 3068 KB
    svchost.exe 1812 4572 KB
    ULCDRSvr.exe 1896 928 KB
    svchost.exe 2616 4188 KB
    alg.exe 2636 3988 KB
    GPU-Z.0.2.8.exe 2892 1696 KB
    3DMark06.exe 3868 27 MB
    wmiprvse.exe 3944 5 MB
    wmiprvse.exe 2016 6 MB
    Logical Drives Drive Letter Label Type Capacity Available
    C: Hard Disk 125 GB 44 GB
    E: GAME+DATA Hard Disk 471 GB 7 GB
    H: XFX_VGA_V16218C CD-ROM 662 MB 0 B
    I: CD-ROM 0 B 0 B
    J: CD-ROM 0 B 0 B
    K: CD-ROM 0 B 0 B
    Storage Devices Device Drive Type Name Manufacturer Model Vendor ID String Product ID String Product Revision String Serial Number Interface Type Device Bus Type Capacity Drive Letters CD Max Read Speed CD Read Capabilities CD Write Capabilities DVD Read Capabilities DVD Write Capabilities SMART Acoustic Management
    Hard Disk WDC WD6400AAKS-65A7B0 (Standard disk drives) WDC WD6400AAKS-65A7B0 WDC WD64 WDC WD6400AAKS-65A7B0 01.03B01 WD-WMASY2581661 IDE ATA 596 GB 0 Not Supported Not Supported
    DVD BENQ DVD LS DW1655 (Standard CD-ROM drives) BENQ DVD LS DW1655 BENQ BENQ DVD LS DW1655 BCHB KWH3606013SC0 IDE ATA 662 MB H: 0 +R, -RW, +RW -R, +R, -RW, +RW Not Supported Not Supported
    DVD DG7533N RKW794G SCSI CdRom Device (Standard CD-ROM drives) DG7533N RKW794G SCSI CdRom Device DG7533N RKW794G 1 <unknown> SCSI 0 B I: 0 -R, -RW -ROM, -R, +R, +RW, -RAM Not Supported Not Supported
    DVD DG7533N RKW794G SCSI CdRom Device (Standard CD-ROM drives) DG7533N RKW794G SCSI CdRom Device DG7533N RKW794G 1 <unknown> SCSI 0 B J: 0 -R, -RW -ROM, -R, +R, +RW, -RAM Not Supported Not Supported
    DVD DG7533N RKW794G SCSI CdRom Device (Standard CD-ROM drives) DG7533N RKW794G SCSI CdRom Device DG7533N RKW794G 1 <unknown> SCSI 0 B K: 0 -R, -RW -ROM, -R, +R, +RW, -RAM Not Supported Not Supported
      งง
        ตาลาย
        เอาแค่หน้า GPU Z กับ 3DMark 06 มาดูก็พอ จะได้วิเคราะถูก
          5555555555555555 ข้อมูลเพียบ
            7950GT X2 กาดจอปี 2006 มาเทียบตอนนี้ยังแรงช้ากว่า 9600GSO/HD3850 ใบเดียวอีกคับ
              เอาแต่เนื้อๆดิครับท่าน - -a
                ข้างบนเป็นผลทดสอบกับ 3D mark 06 ครับ ผมก๊อบมาใส่เลย ทำเป็นไฟลภาพมาใส่ไม่เป็น เอา GPUz มาก็ไม่เป็นครับ
                  Bus Interface มัน@8x นั้นหมายถึงต่อตัวป่าวครับ? ผมดูในGPUz
                    กำ ของ เวร
                    เอารูปใส่เวปนี้มาวาง นะ
                    อย่าเอารูปใหญ่ ละ
                      SM2.0 Score 3680
                        http://upic.me/i/50/7950gx2.gif รูปอยู่นี้จ้า
                          ไดร์เวอร์ เก่าจัด
                          91.47 -..-"
                            เด้วโหลดใดร้เวอใหม่ละกันอิอิอิ แทงยู TWK มีมอไซมือสองขายบะ
                              http://upic.me/show.php?id=2f6afa258...b28447405ababa นี้ใดร้เวอตัวใหม่
