The HIS iClear card is HIS latest solution to video card noise reduction. It has an excellent implement of state-of-the-art design and technology and give you a better gaming experience by reducing the distortion and noise generated from graphic card. It reduces the noise distortion generated from high-end graphics card (from both Radeon and GeForce), TV tuner card and even Hi-Fi Sound Card, and provide up to 10% increase performance on Signal-to-Noise Ratio.
By reducing the distortion and noise generated from the graphics card, it gives the user a better video and gaming experience.
HIS iClear is a card to be installed into any PCI-Express slot (1x, 4x, 16x). You are recommended to install this filter between a graphics card and a device to protect from noise.
HIS iClear card provide up to 10% increase performance on SNR(Signal/Noise _Ratio)
HIS iClear card reduce the noise distortion generate from the highend graphic card or TV tuner card
State-of-the-art design
HIS iFilter card provides a better image with clear picture
HIS iClear card provides better gaming experiences by reduce the distortion and noise generate from graphic card.
It can eliminate the noise generate from high-end card such as 8800GTX, GTS graphic card to provide a "clear picture" when they play can
HIS iClear card provides an ultimate HD experience by reduces the distortion and noise generate from TV tuner card.
