Adrenalin 22.3.1 Recommended (WHQL) 3/17/2022
  • Adrenalin 22.3.1 Recommended (WHQL) 3/17/2022
    AMD Software: Adrenalin Edition 22.3.1 Highlights
    Support For
    • Radeon™ Super Resolution (RSR) Technology – RSRGD-197 is an in-driver spatial upscaling feature that is built on the same algorithm as AMD FidelityFX™ Super ResolutionGD-187 technology. It delivers near-native resolution and increased performance across thousands of games that run in exclusive full screen mode on AMD RDNA-based and newer discrete graphics.
    • AMD Link – Updated AMD Link Play feature now allows up to four users to connect to an AMD Radeon graphics-powered PC from an Android- or Windows-based PC, phone, tablet or TV to play local multiplayer games. AMD Link is also introducing customizable hotkeys, allowing gamers to use their devices to control their gaming experience. AMD Link is now accessible from the Microsoft store and can be downloaded as a standalone application on non-AMD based PCs, inviting an even wider range of users and hardware to join a personal gaming cloud.GD-159
    • Radeon Image Sharpening (RIS) – Bringing crispness and clarity to in-game visuals that have been softened by upscaling and post-process, the latest version of RIS can now be used to enhance visuals in video playback and other productivity applications with a single click.
    • Faster Downloads – Saves time and reduces the driver download size when updating AMD Software: Adrenalin Edition directly from the application, downloading and installing only the files that need updating on the PC.
    • Improved Toast Notifications – Provides users with a clearer snapshot on which key features are enabled or disabled whenever they launch a game.
    Fixed Issues
    • On some AMD Graphics Products such as Radeon™ RX 6800 XT Graphics, the Tuning page within AMD Software: Adrenalin Edition may display incorrect preset selections after installing the latest AMD Software: Adrenalin Edition driver.
    • While playing Forza Horizon 5™ on some AMD Graphics Products such as Radeon™ RX 6800 Graphics, longer than expected load times may be experienced when Ray Tracing is enabled and set at either Medium or High Ray Tracing Quality setting.
    • Visual artifacts may be observed while playing It Takes Two™ on some AMD Graphics Products such as Radeon™ RX 6900 XT Graphics.
    • Enabling Radeon™ Chill for SteamVR™ may lead to inconsistent performances being experienced.
    • After disabling the Hotkeys feature in AMD Software: Adrenalin Edition, some hotkeys still function for some users when they restart their system.
    Known Issues
    • Using Radeon™ Super Resolution on 2560x1600 resolution displays may produce a system hang. A temporary workaround is to set the display Scaling Mode to Full Panel.
    • While playing Cyberpunk 2077™ on some AMD Graphics Products such as Radeon™ RX 570 Graphics, some users may observe an issue where indoor areas appear darker than expected.
    • Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
    • Radeon performance metrics and logging features may intermittently report extremely high and incorrect memory clock values.
    • Some users on Windows® 10 operating system may observe the absence of the windows transparency aero effect.
    อั้บไปแล้ว
    อั้บเสร็จ เมาส์หาย 5555+
    ได้เฟรมมาอีกนิดนึง
      ยังปกติ เล่นอยู่ 3 เกมส์ dota fortnite แล้วก็ตามในรูป
        WHQL
          ดีครับอยากให้ผู้ใช้มายืนยัน
            Fortnite เป็นเหมือนกันไหมครับถ้าปรับ Effect มากกว่า Low เล่นตาแรกจะโหลดนานมาก
              ไม่ได้ลองมากกว่า low เดี่ยวลองให้จะมาบอกอีก
                RX 480 ลองอัพแล้ว เห็นว่าเป็น WHQL ก็เลยอยากลองไม่น่ามีปัญหาอะไร
                  https://youtu.be/ErfOEj4CVi0
                  fsr 2.0
                  ไครลองเเล้วบอกกันด้วยครับ
