เวลาเล่นตุกมากมาย ขนาดเล่นคุณภาพต่ำ สเปคเครื่องก็
System Information
Time of this report: 11/15/2008, 12
27
Machine name: COM
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.060315-1524)
Language: English (Regional Setting: Thai)
System Manufacturer: P4V80
System Model: P4VM800
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz
Memory: 512MB RAM
Page File: 1589MB used, 155MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Display Devices
Card name: ASUS A9250
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9200 PRO AGP (0x5960)
DAC type: Internal DAC(500MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5960&SUBSYS_004C1043&REV_01
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6458 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/10/2004 21
24, 207360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 6/10/2004 21
04, 746496 bytes
Device Identifier: {D7B71EE2-1A20-11CF-C96A-4620A0C2CB35}
Vendor ID: 0x1002
Device ID: 0x5960
SubSys ID: 0x004C1043
Revision ID: 0x0001
Revision ID: 0x0001
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
พอดีอยากจะซื้อการ์ดจอใหม่ด้วย ช่วยแนะนำหน่อยคับหรือต้องเพิ่มเติมอะไรก็บอกหน่อยนะคับ
System Information
27Machine name: COM
Memory: 512MB RAM
Display Devices
24, 207360 bytesWHQL Logo'd: Yes
VDD: n/a
04, 746496 bytesDevice Identifier: {D7B71EE2-1A20-11CF-C96A-4620A0C2CB35}
Vendor ID: 0x1002
Device ID: 0x5960
Revision ID: 0x0001
Revision ID: 0x0001
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
