Radeon Software Adrenalin 2020 Edition Highlights สำหรับ AMD เท่าานั้น
  • Radeon Software Adrenalin 2020 Edition Highlights สำหรับ AMD เท่าานั้น
    Radeon Software Adrenalin 2020 Edition 20.9.1 Highlights
    Fixed Issues
    • A black screen, system crash or TDR may occur while gaming when performing task switches, enabling performance metrics overlay, or having video content/web browsers open on secondary displays on Radeon RX 5000 series graphics products system configurations.
    • Project CARS 3™ may experience performance issues when the Radeon Software performance metrics overlay is enabled.
    • Error 1603 may occur during Radeon Software installation on some AMD Ryzen™ 5 Mobile Processors with Radeon™ Graphics system configurations.
    • Error 195 may occur during Radeon Software installation on some AMD Ryzen™ 3 Mobile Processors with Radeon™ Vega Graphics.
    • On some displays, power cycling the display while Radeon FreeSync is enabled may cause the display to remain black until the system is rebooted or the display is hot plugged.
    • Flickering may occur in Borderlands™ 3 in some locations when Radeon Boost is enabled.
    • Decoding some HEVC content using AMF Decoder may result in corruption in the clips playback.
    • Performance Tuning fan profiles may sometimes not be applied after loading a saved profile.
    • Radeon Software may sometimes crash or automatically exit when performing a game scan in the Gaming tab.
    • Random color corruption may intermittently occur on some surfaces while playing matchmaking in Counter-Strike™: Global Offensive.
    • Notifications may be missing icons or text when hotkeys are used to invoke some Radeon Software streaming and recording features.
    • Brightness flickering may be experienced on some VP9 video content playback through applications or web browsers on Radeon RX 5000 series graphics product system configurations.
    Known Issues
    • Project CARS 3™ may experience mirror like corruption when using VR during game menus on GCN based Radeon graphics products.
    • With Radeon FreeSync enabled on Radeon RX 5000 series system configurations, task switching to another display or application may cause the display to flicker for a few moments or for the displays refresh rate to spike.
    • Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
    • Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
    • With HDR enabled, Windows® desktop may experience flickering, and performing a task switch while in a game may cause colors to become washed out or over saturated.
    • Audio may experience instability when connected through an Audio Video Receiver via HDMI® on Radeon RX 5000 series graphics products.
    • Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
    • Some games may exhibit stutter intermittently during gameplay on Radeon RX 5000 series graphics products.
    https://www.amd.com/en/support/kb/re...rad-win-20-9-1
      Radeon Software Adrenalin 2020 Edition 20.9.2 Highlights
      Support For
      • STAR WARS™: Squadrons
      Added Vulkan® Support
      • VK_KHR_buffer_device_address
        • This extension is used to query the device address of a buffer to allow for shader access to that buffer’s storage via the SPV_KHR_physical_storage_buffer SPIRV extension.
      • VK_EXT_robustness2
        • This extension provides stricter restrictions for handling reads and writes that are out of bounds. It specifies that out-of-bounds reads must return zeros and out-of-bounds writes must be discarded. This extension also adds support for null descriptors.
      • VK_EXT_shader_image_atomic_int64
        • This extension extends existing 64-bit integer atomic support to images, which provides more efficient access than buffers. This allows applications to quickly improve their performance with minor changes to their code.
      Fixed Issues
      • Radeon FreeSync may fail to enable after updating Radeon Software without a system reboot.
      • Screen flickering may be observed while MSI Afterburner™ is running or enabled on the system.
      • X-Plane 11™ may experience an application hang or crash when using the Vulkan® API.
      • DOOM™ VFR may experience corruption or artifacting in game on Radeon RX 5000 series system configurations.
      • Performance metrics overlay may fail to open or appear after the system wakes from sleep.
      • Call of Duty®: WWII may experience black textures on the ground or walls in zombies game mode.
      • Blocky corruption may be observed in Detroit: Become Human™ on some Radeon RX 5000 series graphics products.
      • Using the Movies&TV application to edit video clips may result in green corruption in the clips.
      • Performance metrics may report incorrect values for current VRAM usage after an extended period of gameplay.
      • World of Warcraft™ may experience corruption issues with anti-aliasing enabled on DirectX®12 API.
      • Launching Radeon Software after a driver upgrade, may cause the Auto OC dialogue to appear with “0 Mhz” when the Auto OC feature has been previously enabled on Radeon RX Vega series graphics products.
      Known Issues
      Download drivers and software for AMD products — includes Windows and Linux support, auto-detect tools & detailed guides for installation.
        ออกมาจะครึ่งเดือนละพี่ ใช้อยู่ก็ไม่เจอปัญหาไรนะ
            กับวินโดว์ไดรฟเวอร์โดนด่าเยอะแต่ถ้า Linux นีจัดกันยาวๆๆ no พรอมแพรมเลย
              Radeon Software Adrenalin 2020 Edition 20.10.1 Highlights
              Support For
              • Doom™ Eternal: The Ancient Gods
              • Watch Dogs™: Legion
              • DIRT 5™ Early Access
              • World of Warcraft™: Shadowlands Pre-Patch
              Fixed Issues
              • Desktop may experience frame rate fluctuation when exiting a Vulkan® API game with Radeon FreeSync enabled on two or more display system configurations.
              • Uploading or streaming content to YouTube™ may be unavailable or not working correctly.
              • Genshin Impact™ is not detected or listed in Radeon Software gaming tab.
              • Some specific Windows® screensavers such as ‘Bubbles’ may cause an application crash when applied on Radeon RX 5000 series graphics products.
              • Graphical corruption may occur on desktop or at idle when two or more connected high refresh rate displays are Radeon FreeSync enabled on Radeon RX 5000 series graphics products.
              • Upgrading to Radeon Software Adrenalin 2020 Edition releases from Radeon Software 2019 Edition releases via Radeon Settings may sometimes fail with an error message.
              Known Issues
              https://www.amd.com/en/support/kb/re...ad-win-20-10-1
                  ขุดดีขึ้นไหมครับ
                    เหนื่อยกับคำว่า "ซื้อชาตินี้แรงชาติหน้า" ตัดใจไป RTX20XX และ
                      AMD Radeon Adrenalin 2020 20.11.1
                      Support For
                      • DIRT 5™
                      • Assassin’s Creed Valhalla™
                      • Godfall™
                        • Using Radeon™ Software Adrenalin 2020 edition 20.11.1, a Radeon™ RX 5700 XT GPU offers on average 7% better FPS performance in Godfall (DX12) on the High setting, vs. the previous driver iteration, Radeon Software Adrenalin 2020 edition 20.10.1.RS-348
                        • Call of Duty®: Black Ops Cold War
                      Known Issues
                      https://videocardz.com/driver/amd-ra...n-2020-20-11-1
                        AMD Radeon Adrenalin 2020 20.11.3
                        Support For
                        • Immortals: Fenyx Rising™
                        • Vulkan® Ray Tracing Extensions
                        • VK_KHR_fragment_shading_rate
                          • This extension provides the ability to change the shading rate per fragment. This extension allows for multiple pixels to be shaded via a single fragment shader invocation as opposed to the normal rate of one invocation per pixel.
                        • VK_KHR_acceleration_structure
                          • This extension provides acceleration structures for representing geometry that is spatially sorted. Acceleration structures are the most common way for quickly identifying potential ray intersections by ray tracing techniques.
                        • VK_KHR_ray_tracing_pipeline
                          • This extension introduces ray tracing pipelines along with new shader domains and an indirection table to link shader groups with acceleration structures.
                        • VK_KHR_ray_query
                          • This extension introduces ray queries, which can be used by any shader type outside of the optional dedicated ray tracing pipeline to return traversal results to the calling shader.
                        • VK_KHR_deferred_host_operations
                          • This extension defines the infrastructure and usage patterns for deferrable commands, which allows dependent extensions to defer their own operations. The VK_KHR_deferred_host_operations extension itself does not specify any commands as deferrable.
                        • VK_KHR_pipeline_library
                          • This extension introduces pipeline libraries. A pipeline library is a new special pipeline type that defines a set of pipeline states. It cannot be bound, rather it can be linked into other pipelines.
                        • VK_KHR_shader_terminate_invocation
                          • This extension indicates support for the SPV_KHR_terminate_invocation SPIR-V extension. The SPIR-V extension introduces a new instruction OpTerminateInvocation that allows a shader invocation to immediately terminate, which provides the behavior required by the GLSL discard statement.
                        Fixed Issues
                        • Lower than expected performance may be experienced on Radeon™ RX 6000 series graphics products in Watchdogs:® Legion and Dirt™ 5.
                        • Lower than expected performance may be experienced on Radeon™ RX 5000/500/400 series graphics products in Godfall™.
                        • Godfall™ is not detected or listed in Radeon Software gaming tab.
                        • Crysis™ Remastered may experience corruption on character models on Radeon™ RX 6800 Series graphics products.
                        • Fixed some intermittent crashes found in Total War™ Saga: Troy and World of Warcraft®: Shadowlands.
                        • World of Warcraft®: Shadowlands may fail to launch when DirectX®12 API is selected on Windows®7 system configurations.
                        • Fixed some intermittent crashes found in Call of Duty®: Black Ops Cold War with DirectX® Raytracing enabled.
                        • HDR on supported Windows 10 desktops might get disabled when DOOM® Eternal™ starts rendering in HDR mode.
                        • Fixed issues found on Adobe™ Illustrator, Adobe™ Premier and FinalWire AIDA64.
                        • Fixed corruption issues in Red Dead Redemption 2 in 1080p resolution on Radeon™ RX 6800 Series graphics products.
                        Known Issues
                        • Brightness flickering may intermittently occur in some games when Radeon™ FreeSync is enabled, and the game is set to use borderless fullscreen.
                        • Metro Exodus™, Shadow of the Tomb Raider™, Battlefield™ V and Call of Duty®: Modern Warfare may experience intermittent application crashes with DirectX® Raytracing enabled.
                        • Anisotropic Filtering in Radeon™ Software graphics settings is not taking effect in DirectX®9 applications on RDNA graphics products.
                        • Some games may experience stuttering when set to borderless fullscreen and an extended display is connected running the Netflix™ windows store application on RDNA graphics products.
                        • Radeon™ recording and streaming features may fail to enable on AMD Radeon™ HD 7800 series graphics products.
                        • Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon™ RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
                        • Oculus Link users might experience crashes on Polaris and Vega series graphics products.
                        • Flickering might be observed if the Radeon Software Overlay is invoked while Immortals: Fenyx Rising™ is running on an extended display.
                        • Tom Clancy’s Rainbow Six® Siege might experience corruption in Hybrid Graphics scenarios when using the Vulkan API on an extended display.
                        • Screen flickering might be observed when using MSI Afterburner.
                        https://www.amd.com/en/support/kb/re...ad-win-20-11-3
                          AMD Radeon Adrenalin 2020 20.12.1
                          Support For
                          • Radeon™ RX 6900 Series
                          • Cyberpunk 2077™
                          Fixed Issues
                          • Gaming applications can sometimes get stuck running at lower than expected graphics clocks on Radeon RX 6800 series graphics products.
                          • The HP Reverb G2 VR headset may fail to sync or may have a black screen when run with Radeon RX 6800 series graphics products.
                          • Tom Clancy’s Rainbow Six® Siege may experience corruption in Hybrid Graphics scenarios when using the Vulkan API on an extended display.
                          • Crossfire™ may experience issues when attempting to change the games resolution to a 16:9 ratio.
                          Known Issues
                          • Some displays such as the Sceptre C series or Samsung™ Odyssey G9 series may experience an intermittent black screen on Radeon RX 6000 series graphics products.
                          • The Samsung™ Odyssey G9 C49G95T may experience display or corruption issues when set to 5120×1440@240hz.
                          • Oculus Link users may experience intermittent crashes on Polaris and Vega series graphics products.
                          https://www.amd.com/en/support/kb/re...ad-win-20-12-1
                            ถามนิดครับ เผื่อมีคนตอบ
                            จอ support freesync premuim pro ควรใช้การ์ดจอ amd ไหมครับ หรือไม่มีผลอะไรมาก
                            เริ่มทนรอไม่ไหว+เห็นราคาแล้วท้อ ลังเลอยากไปเขียว
                              ไปเขียวได้ รอราคาลงค่อยขายเขียวทิ้ง
