Radeon Software Adrenalin 2020 Edition 20.8.3 12% DX12 มาแล้วนะคะ
  • Radeon Software Adrenalin 2020 Edition 20.8.3 12% DX12 มาแล้วนะคะ
    AMD Radeon Adrenalin 2020 20.8.3
    Radeon Software Adrenalin 2020 Edition 20.8.3 Highlights
    Support For
    • Project CARS 3™
    • Marvel’s Avengers™
    • Fortnite™
      • Using AMD’s latest driver Radeon™ Software Adrenalin 2020 edition 20.8.3, a Radeon™ RX 5700 XT GPU offers an average 12% better FPS performance in Fortnite™ (DX12) on the Epic setting, vs. the previous driver iteration, Radeon Software Adrenalin 2020 edition 20.8.1.RS-340
    Added Vulkan® Support
    • VK_EXT_extended_dynamic_state
      • This extension adds more dynamic states. This allows applications to reduce the need to recompile and bind pipeline state objects.
    • VK_EXT_private_data
      • This extension allows applications to store application-defined data in a 64-bit private data slot.
    • VK_EXT_image_robustness
      • This extension adds stricter requirements such that drivers return default RGBA values instead of undefined values for out-of-bounds reads. The number of components returned depends on the number of components present in the selected format.
    • VK_GOOGLE_user_type
      • This extension indicates the driver’s support for shader modules using the SPV_GOOGLE_user_type SPIR-V extension.
    Fixed Issues
    • Mortal Shell™ may experience a game or application crash when opening the inventory window in game.
    • Enabling HDR on some Radeon FreeSync 2 displays, may intermittently cause the display refresh rate to be forced to the FreeSync ranges minimum refresh rate during gameplay.
    • Surviving Mars™ may experience an application crash or hang at launch on Radeon RX 5000 series graphics products.
    • eFootball PES 2020™ may experience an application crash at launch on Radeon RX 5000 series graphics products.
    • Radeon Overlay may not be available or may fail to invoke on Hybrid Graphics system configurations when playing Hyper Scape™.
    • Counter-Strike: Global Offensive™ may experience intermittent stutter when some applications are running in the background such as third party matchmaking clients or Discord™.
    • YouTube playback may become frozen with Microsoft® Edge player and Chrome™ when played on an extended display on some AMD Ryzen™ 7 3000 series and AMD Ryzen™ 4000 series APU system configurations.
    Known Issues
    • Project CARS 3™ may experience mirror like corruption when using VR during game menus on GCN based Radeon graphics products.
    • Project CARS 3™ may experience performance issues when the Radeon Software performance metrics overlay is enabled.
    • Performance issues may be experienced when playing Horizon Zero Dawn™ on select Radeon Vega graphics.
    • With Radeon FreeSync enabled on Radeon RX 5000 series system configurations, task switching to another display or application may cause the display to flicker for a few moments.
    • Brightness flickering may be experienced on some VP9 video content playback through applications or web browsers on Radeon RX 5000 series graphics product system configurations.
    • Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
    • Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
    • With HDR enabled, Windows® desktop may experience flickering, and performing a task switch while in a game may cause colors to become washed out or over saturated.
    • Audio may experience instability when connected through an Audio Video Receiver via HDMI® on Radeon RX 5000 series graphics products.
    • Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
    • Some games may exhibit stutter intermittently during gameplay on Radeon RX 5000 series graphics products.
    • AMD will continue to monitor and investigate any new reports of black screen or system hang issues during extended periods of gameplay closely. Users are encouraged to use the new Bug Reporting Tool for any issues they may encounter.
    Footnotes
    • RS-340, Testing by AMD Performance Labs as OF August 24, 2020 using a test system configured with an Ryzen 7 3800XT CPU, 16GB DDR4-3200MHz memory, a Radeon™ RX 5700 XT graphics card and Windows 10 x64 with Radeon Software Adrenalin 2020 Edition 20.8.3, vs. a similarly configured system with Software Adrenalin 2020 Edition 20.8.1, using the game Fortnite™ on the Epic preset and DirectX®12. Performance may vary.
    Important Notes
    • AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2020 Edition can be found here.
    Package Contents
    The Radeon Software Adrenalin 2020 Edition 20.8.3 installation package contains the following:
    • Radeon Software Adrenalin 2020 Edition 20.8.3 Driver Version 20.20.27.01 (Windows Driver Store Version 27.20.12027.1001).
    The Radeon Software Adrenalin 2020 Edition 20.8.3 installation package can be downloaded from the following links:
    By clicking the Download button, you are confirming that you have read and agreed to be bound by the terms and conditions of the End User License Agreement (“EULA”). If you do not agree to the terms and conditions of these licenses, you do not have a license to any of the AMD software provided by this download.Installing Radeon Software Adrenalin Edition
    For detailed instructions on how to correctly uninstall or install Radeon Software Adrenalin Edition, please refer to the following support resources:NOTE:
    This driver is not intended for use on AMD Radeon products running in Apple Boot Camp platforms. Users of these platforms should contact their system manufacturer for driver support.
    When installing Radeon Software Adrenalin 2020 Edition 20.8.3 for the Windows® operating system, the user must be logged on as Administrator, or have Administrator rights to complete the installation of Radeon Software Adrenalin Edition 20.8.3.
    Radeon Product Compatibility
    Radeon Software Adrenalin 2020 Edition 20.8.3 is compatible with the following AMD Radeon products.
    Radeon™ RX 5700 Series Graphics AMD Radeon™ R9 Fury Series Graphics
    Radeon™ RX 5600 Series Graphics AMD Radeon™ R9 Nano Series Graphics
    Radeon™ RX 5500 Series Graphics AMD Radeon™ R9 300 Series Graphics
    Radeon™ RX 5300 Series Graphics AMD Radeon™ R9 200 Series Graphics
    Radeon™ VII AMD Radeon™ R7 300 Series Graphics
    Radeon RX Vega Series Graphics AMD Radeon™ R7 200 Series Graphics
    AMD Radeon™ Pro Duo AMD Radeon™ R5 300 Series Graphics
    Radeon™ RX 500 / Radeon 500X Series Graphics AMD Radeon™ R5 200 Series Graphics
    Radeon™ 540 Series Graphics AMD Radeon™ HD 8500 - HD 8900 Series Graphics
    Radeon™ RX 400 Series Graphics AMD Radeon™ HD 7700 - HD 7900 Series Graphics
    Mobility Radeon™ Product Compatibility
    Radeon Software Adrenalin 2020 Edition 20.8.3 is a notebook reference graphics driver with limited support for system vendor specific features.
    AMD Radeon RX 5500M Series Graphics AMD Radeon™ R5 M300 Series Graphics
    AMD Radeon RX 5300M Series Graphics AMD Radeon™ R9 M200 Series Graphics
    AMD Radeon™ 600 Series Graphics AMD Radeon™ R7 M200 Series Graphics
    AMD Radeon™ R7 M400 Series Graphics AMD Radeon™ R5 M200 Series Graphics
    AMD Radeon™ R9 M300 Series Graphics AMD Radeon™ HD 8500M - HD 8900M Series Graphics
    AMD Radeon™ R7 M300 Series Graphics AMD Radeon™ HD 7700M - HD 7900M Series Graphics
    ​​​​AMD Processors with Radeon Graphics Product Compatibility
    Important Note for Laptop and All-In-One (AIO) PCs
    AMD recommends OEM-provided drivers which are customized and validated for their system-specific features and optimizations.
    If you experience issues using the Radeon™ Software Adrenalin Edition driver package downloaded from AMD.com, please install the OEM-provided drivers for full support and compatibility.
    AMD Ryzen™ Processors with Radeon™ Vega graphics AMD Ryzen™ Mobile processors with Radeon™ Vega graphics
    AMD Ryzen™ PRO Processors with Radeon™ Vega graphics AMD Athlon™ Mobile Processors with Radeon™ Vega Graphics
    AMD Athlon™ Processors with Radeon™ Vega Graphics AMD A-Series and FX processors with Radeon graphics
    AMD Athlon™ PRO Processors with Radeon™ Vega Graphics AMD Ryzen™ PRO Mobile processors with Radeon™ Vega graphics
    AMD A-Series APUs with Radeon™ R4, R5, R6, or R7 Graphics AMD Athlon™ PRO Mobile processors with Radeon™ Vega graphics
    AMD Pro A-Series APUs with Radeon™ R5 or R7 Graphics AMD A-Series™ PRO processors with Radeon™ graphics
    AMD Athlon™ Series APUs with Radeon™ R3 Graphics AMD 3015e with Radeon Graphics
    AMD Sempron™ Series APUs with Radeon™ R3 Graphics AMD FX-Series APUs with Radeon™ R7 Graphics
    AMD E-Series APUs with Radeon™ R2 Graphics
    AMD Radeon™ HD 8180 - HD 8400 Series Graphics
    Compatible Operating Systems
    Radeon Software Adrenalin 2020 Edition 20.8.3 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
    • Windows® 10 64-bit version
    • Windows® 7 64-bit version
    ​​​© 2020 Advanced Micro Devices, Inc. All Rights Reserved.
    DISCLAIMER
    The information contained herein is for informational purposes only and is subject to change without notice. While every precaution has been taken in the preparation of this document, it may contain technical inaccuracies, omissions and typographical errors, and AMD is under no obligation to update or otherwise correct this information. Advanced Micro Devices, Inc. makes no representations or warranties with respect to the accuracy or completeness of the contents of this document and assumes no liability of any kind, including the implied warranties of non-infringement, merchantability or fitness for particular purposes, with respect to the operation or use of AMD hardware, software or other products described herein. No license, including implied or arising by estoppel, to any intellectual property rights is granted by this document. This notice does not change the terms and limitations applicable to the purchase or use of AMD's products that may be set forth in a separate signed agreement between you and AMD.
    OVERCLOCKING WARNING: AMD processors are intended to be operated only within their associated specifications and factory settings. Operating your AMD processor outside of official AMD specifications or outside of factory settings, including but not limited to the conducting of overclocking (including use of this overclocking software, even if such software has been directly or indirectly provided by AMD or otherwise affiliated in any way with AMD), may damage your processor and/or lead to other problems, including but not limited to, damage to your system components (including your motherboard and components thereon (e.g. memory)), system instabilities (e.g. data loss and corrupted images), reduction in system performance, shortened processor, system component and/or system life and in extreme cases, total system failure. AMD does not provide support or service for issues or damages related to use of an AMD processor outside of official AMD specifications or outside of factory settings. You may also not receive support or service from your board or system manufacturer. Please make sure you have saved all important data before using this overclocking software. DAMAGES CAUSED BY USE OF YOUR AMD PROCESSOR OUTSIDE OF OFFICIAL AMD SPECIFICATIONS OR OUTSIDE OF FACTORY SETTINGS ARE NOT COVERED UNDER ANY AMD PRODUCT WARRANTY AND MAY NOT BE COVERED BY YOUR BOARD OR SYSTEM MANUFACTURER’S WARRANTY.
    The software that has been directly or indirectly provided by AMD or an entity otherwise affiliated with AMD may disable or alter: (1) software including features and functions in the operating system, drivers and applications, and other system settings; and (2) system services. WHEN THE SOFTWARE IS USED TO DISABLE OR ALTER THESE ITEMS IN WHOLE OR PART, YOU MAY EXPERIENCE (A) INCREASED RISKS THAT CERTAIN SECURITY FUNCTIONS DO NOT FUNCTION THEREBY EXPOSING YOUR COMPUTER SYSTEM TO POTENTIAL SECURITY THREATS INCLUDING, WITHOUT LIMITATION, HARM FROM VIRUSES, WORMS AND OTHER HARMFUL SOFTWARE; (B) PERFORMANCE AND INTEROPERABILITY ISSUES THAT MAY ADVERSELY AFFECT YOUR EXPERIENCE AND THE STABILITY OF YOUR COMPUTING SYSTEM; AND (C) OTHER EXPERIENCES RESULTING IN ADVERSE EFFECTS, INCLUDING, BUT NOT LIMITED, TO DATA CORRUPTION OR LOSS.
    AMD, the AMD Arrow logo, AMD Radeon, AMD Freesync and combinations thereof are trademarks of Advanced Micro Devices, Inc.
    Windows and DirectX are registered trademarks of Microsoft Corporation.
    Vulkan and the Vulkan logo are registered trademarks of the Khronos Group Inc.
    Other names used herein are for identification purposes only and may be trademarks of their respective companies.
    Download drivers and software for AMD products — includes Windows and Linux support, auto-detect tools & detailed guides for installation.
    อัพแล้วยังไม่ระเบิด
      อัพแล้ว ซิลิโคลนบน GPU เสื่อม จขกท. รับผิดชอบด้วยครับ
        ซื้อต่อ 5 บาท
          Originally posted by THEFOOL View Post
          ซื้อต่อ 5 บาท
          ขายผมดีก่า ให้ 20 ok เดลเลย
              win10-radeon-software-adrenalin-2020-edition-20.8.3-sep8 WHQL
                อัพ WHQL ปุ๊ป ก็เล่นผมเลย ไอเปรต
                ลงโปรแกรม ADNR + ไดเวอร์การ์ดจอ ลงได้ปกติ ภาพเข้า Windows ขึ้นปกติ แต่เปิด Chrome /MS Edge จอดำไม่ขึ้นอะไร
                ถ้าลง ไดเวอร์การ์ดจอผ่าน Device Manager อย่างเดียวแบบที่เคยทำ พอตอนหาไดเวร์ในโฟเดอร์ เครื่องดับเอง
                ปล. ก่อนหน้าใช้ตัว 20.8.3 Beta ปกตินะ ไม่มีปัญหาอะไร ไอเปรตตตต
                  เสียแล้ว ซื้อต่อ ห้าบาท
                    แพงไป
                      Windows 10 => Window Update มันจะ Downgrade Driver ทำไงดีครับ ^_^"
