ใครเคยใช่หรือรู้บอกที่นะคับ
ราคาตัว 1GB 6240บาท ถ้าตัว512M 5200บาท
Model
Brand ASUS
Model EN9600GT/HTDI/1G
Interface
Interface PCI Express 2.0 x16
Chipset
Chipset Manufacturer NVIDIA
GPU GeForce 9600GT
Core clock 650MHz
Stream Processors 64
Memory
Memory Clock 1800MHz
Memory Size 1 GB
Memory Interface 256-bit
Memory Type GDDR3
3D API
DirectX DirectX 10
OpenGL OpenGL 2.0
Ports
DVI 2
TV-Out HDTV / S-Video Out
VIVO No
General
Tuner None
RAMDAC 400 MHz
Max Resolution 2560 x 1600
RoHS Compliant Yes
SLI Supported Yes
Cooler With Fan
Dual-Link DVI Supported Yes
HDCP Ready Yes
Features
Features Full Microsoft DirectX 10 Support
HDCP compliant
NVIDIA SLI Technology
NVIDIA PureVideo HD technologyEssential for the Ultimate HD Movie Experience on a PC
Packaging
Package Contents EN9600GT/HTDI/1G
Driver Disk
User Manual
HDTV Cable
Power Cable
DVI to VGA/D-sub Adapter
DVI to HDMI Adapter
S/PDIF Cable
Model
Brand ASUS
Interface
Chipset
GPU GeForce 9600GT
Core clock 650MHz
Memory
Memory Size 1 GB
Memory Type GDDR3
3D API
DirectX DirectX 10
OpenGL OpenGL 2.0
Ports
DVI 2
VIVO No
General
Tuner None
RAMDAC 400 MHz
RoHS Compliant Yes
SLI Supported Yes
Cooler With Fan
HDCP Ready Yes
Features
HDCP compliant
Packaging
Driver Disk
User Manual
HDTV Cable
Power Cable
DVI to HDMI Adapter
S/PDIF Cable
