ATI Catalyst 8.6 ออกแล้ว
  • ATI Catalyst 8.6 ออกแล้ว
    The Catalyst™ software suite 8.6 contains the following:
    * Radeon™ display driver 8.501
    * Multimedia Center™ 9.16 (Windows XP only)
    * HydraVision™ for both Windows XP and Vista
    * HydraVision™ Basic Edition (Windows XP only)
    * Remote Wonder 3.04 (Windows XP only)
    * WDM Driver Install Bundle
    * Southbridge/IXP Driver
    * Catalyst™ Control Center Version 8.6
    Catalyst™ 8.6 introduces the following new features:
    - OpenGL Adaptive Anti-Aliasing Custom Filters support
    - OpenGL CrossFireX™ (QUAD) support - 3 or 4 GPUs in CrossFire™ mode
    - Catalyst Install enhancement - No reboot required after Catalyst upgrade install
    ไปโหลดกันเลย
    ลงแล้วเป็นไงบ้างบอกด้วยนะครับ ผมยังไม่มีเวลาลงเลย
    ข่าวล่ามาไว ก่อนนอนขอลองก่อน ^^
    Performance Improvements
    The following performance gains are noticed with this release of Catalyst™.
    * 3DMark Vantage:10 to 15% gains across all Radeon™ HD 3xxx and HD 2xxx products, with larger gains in specific cases.
    * Call of Duty 4: Performance increases across all Radeon™ HD 3xxx and HD 2xxx products, with gains as large as 35% in specific maps.
    * Call of Juarez DX10: Performance increases between 2 and 9% across all HD 3xxx and HD 2xxx products
    * Company of Heroes (DX10 version): Performance increases between 4 and 10% across HD 36xx and HD 34xx products.
    * Lost Planet (DX10 version): Performance increases by 1 or 2 fps across all HD 3xxx and HD 2xxx products, creating in some cases up to 20% increase.
    * Lost Planet (DX9 version): Performance increases between 2 and 20% across all HD 3xxx and HD 2xxx products
    * Prey OpenGL: 3-5% gains across HD 3xxx and HD 2xxx products.
    * Quake 4 OpenGL: Up to 8% increase across all HD 3xxx and HD 2xxx products.
    * Shadermark 2.1: Minor improvements across all HD 3xxx and HD 2xxx products, with the largest gains appearing on HD 3650 (up to 9%)
    * ViewPerf 10: Substantial performance improvements across several of the sub-tests, with the largest gains in ugnx (up to 55%), catia (up to 17%) and tcvis (up to 10%) across all of the HD 3xxx and HD 2xxx products.
        ใครลองแล้วบอกหน่อยว่าดีไหม
        ตอนใช้ 8.5 เล่น Crysis ก้อนหินมีบ้าง ไม่มีบ้าง
        เลยกลับมาใช้ 8.3 ไปก่อน
            ถ้าตามนี้ดูท่าจะแรงขึ้นนะโหลดมาแล้วล่ะ แต่ไม่มีการ์ดลอง 555
              เลิกใช้ละ เหนื่อยอัพ 7.10ดีสุด
                8.5 สำหรับผม มีปัญหา พอสมควร
                เลยกลับมาใช้ 8.4
                ส่วน 8.6 เดี๋ยวจะลองหน่อยก๊าบบบบ
                  ขึ้นเขียงทดลองอยู่ครับ
                    ขอให้มันแจ่ม เหอะ สาธุ ><"
                        ไมผมใช้กับ x1950pro แล้วพอเข้าเกมไปสักแปบ จอมืดเลยงะ เดียวจะลองหลายๆเกมดูครับ
                            ไม่มีทางเลือกมากมาย สำหรับ HD4850 ลองแล้ว
                            crysis เพิ่มมานิดหนึ่ง
                              AGP & Mobility
