Radeon Software Adrenalin 2019 Edition 19.7.3 Up to 13% better performance Wolfenstei
  • Radeon Software Adrenalin 2019 Edition 19.7.3 Up to 13% better performance Wolfenstei
    Radeon Software Adrenalin 2019 Edition 19.7.3 Highlights
    Support For
    Wolfenstein™: Youngblood
    Up to 13% better performance with Radeon™ Software Adrenalin 2019 Edition 19.7.3 in Wolfenstein: Youngblood than with Radeon™ Software Adrenalin 2019 Edition 19.7.2RS-304
    Radeon GPU Profiler on Radeon RX 5700 series graphics products
    Microsoft PIX on Radeon RX 5700 series graphics products
    Added Vulkan® Support
    VK_EXT_display_surface_counter
    This extension defines a vertical blanking period counter associated with display surfaces. It provides a mechanism to query support for such a counter from a VkSurfaceKHR object
    VK_AMD_pipeline_compiler_control
    This extension provides a way to set per-pipeline compiler options, for instance, to relax rounding rules when working with mixed-precision floating point values.
    VK_AMD_shader_core_properties2
    This extension exposes additional, AMD specific shader core properties for a physical device
    VK_EXT_subgroup_size_control
    This extension provides additional control over subgroup size, allowing applications for instance to opt-in to different subgroup sizes on devices supporting more than just one.
    VK_KHR_imageless_framebuffer
    This extension allows framebuffers to be created without the need for creating images first, allowing more flexibility in how they are used, and avoiding the need for many of the compatibility rules.
    VK_KHR_variable_pointers
    This extension allows implementations to indicate their level of support for the SPV_KHR_variable_pointers SPIR-V extension. The SPIR-V extension allows shader modules to use invocation-private pointers into uniform and/or storage buffers, where the pointer values can be dynamic and non-uniform. This release adds the optional VariablePointers support.
    Fixed Issues
    League of Legends™ may fail to launch on Radeon RX 5700 Series Graphics with Windows®7 system configurations.
    Radeon RX 5700 series graphics products may experience DirectX®9 application crashes or hangs after an express upgrade of Radeon Software.
    Windows Mixed Reality may fail to launch when Radeon Image Sharpening is enabled on Radeon RX 5700 series graphics products.
    Audio may be out of sync with videos when using Radeon ReLive VR.
    Incorrect values may be shown in the power gauge for Radeon WattMan while applications are running on AMD Radeon VII.
    AMD Log Utility Driver may intermittently fail to install on Windows®7 system configurations.
    Radeon Anti-Lag may experience slight performance drops on some gaming applications when enabled.
    Minor stuttering may occur when playing Fortnite™ during the first few minutes of gameplay on AMD Radeon RX 5700 Series Graphics.
    Radeon Overlay may experience flickering in Vulkan® API games when Radeon Image Sharpening is enabled.
    Corruption may be observed in some tests when running Adobe™ Premier Pro 2019 benchmarks.
    Known Issues
    Some system configurations may experience green color corruption after install of Radeon Software when running Windows® 10 May 2019 update.
    Stutter may be experienced when Radeon FreeSync is enabled on 240hz refresh displays with Radeon RX 5700 series graphics products.
    Radeon Performance Metrics may report incorrect VRAM utilization.
    AMD Radeon VII may experience elevated memory clocks at idle or on desktop.
    Radeon Overlay may intermittently fail to appear when toggled in game.
    Audio for clips captured by Radeon ReLive may be corrupted or garbled when desktop recording is enabled.
    Radeon RX 5700 Series Graphics may experience a black screen during uninstall on Windows®7 system configurations. A work around is to perform uninstall in safe mode.
    Recording clips with Radeon ReLive may result in blank clips on Radeon RX 5700 Series Graphics with Windows®7 system configurations.
    Enabling Enhanced Sync may cause game, application or system crashes on Radeon RX 5700 series graphics products.
    Footnotes
    RS-304 - Testing conducted by AMD Performance Labs as of July 24th, 2019 on the 8GB Radeon™ RX 5700, using a test system comprising of Intel i7 9700K CPU (3.6 GHz), 16GB DDR4-3200MHz memory, and Windows 10x64 with Radeon Software Adrenalin 2019 Edition 19.7.2. and 19.7.3. PC manufacturers may vary configurations, yielding different results. With Radeon™ Software Adrenalin 2019 Edition 19.7.2, running Wolfenstein: Youngblood (Vulkan) on the “Mein Leben” preset scored 55.6 FPS (average of three runs) whereas Radeon™ Software Adrenalin 2019 Edition 19.7.3, running Wolfenstein: Youngblood (Vulkan) on the “Mein Leben” preset scored 62.7 FPS (average of three runs) for a total of 13% uplift in performance driver over driver . Performance may vary based on use of latest drivers.
    Download drivers and software for AMD products — includes Windows and Linux support, auto-detect tools & detailed guides for installation.
    เมพจังคับ
      เมพจังคับ
      สงสัยลืมสลับไอดี
        อยากดูแบบ VDO ครับ
        โหเฉลี่ย Driver 2 @ 55FPS vs 3 @ 62FPS ไม่น้อยนะครับเนี่ย
        แล้ว Radeon 2XX-5XX ผลดีขึ้นมากไหม
        อยากดูแบบ youtube โชว์ FPS เทียบแบบ Real-time มากเลย คงตื่นตามากๆ นะครับเนี่ย
          3 มาได้ไม่กี่วัน 4 ก็มาแล้วครับ Vega 64 ผมยังอยู่ที่เดิม ขี้เกียจอัปแล้ว
            https://www.amd.com/en/support/kb/re...rad-win-19-7-4
            อีก 1-2 วันก็จะ 19.8.1 มาครับ
