Riva Tuner 2.08
  • Riva Tuner 2.08
    ใครรู้แล้วก็ขออภัยน่ะครับ ว่าแต่มันเพิ่งออกตัว 2.07 เองหนิครับ
    รองรับการ์ดตัวใหม่ๆ
      มาไวจริง พึ่งจะ install 2.07 ไปเมื่อวาน - -
        ผมพึ่งลง 2.07 ไปเมื่อกี้ครับ มันเพิ่มไรบ้างครับ อันใหม่เนี่ย
          Software Description
          Rivatuner is one the leading tweak utility available for NVIDIA GeForce and ATI Radeon based videocards.
          What's a graphics card tweaker without the proper tools to do so ? Exactly; Rivatuner has been updated towards version 2.08 In this release we have included a huge number of stuff to keep you busy, obviously GeForce
          9600 GT & ForceWare 174.xx support is here as well.
          RivaTuner is a complete powerful tweaking environment, providing you everything you may need to tune NVIDIA GPU based display adapters. The widest driver-level Direct3D / OpenGL and system tuning options, flexible profiling system allowing to make custom settings on per-application basis, both driver-level and low-level hardware access modes, unique diagnostic and real-time hardware monitoring features and exclusive power user oriented tools like built-in registry editor and patch script engine make RivaTuner's feature set absolutely unmatched. RivaTuner supports all NVIDIA display adapters starting from Riva TNT family up to the latest GeForce
          9 series and widest range of NVIDIA drivers starting from the oldest Detonator 2.08 up to the newest ForceWare drivers family.
          In addition to complete NVIDIA hardware support, RivaTuner also provides limited support for display adapters based upon ATI RADEON 8500 and newer ATI graphics processors. All RivaTuner's features besides driver-level tuning options are also available on supported ATI hardware.
          Guru3D.com is Rivatuner's official homepage, click here to find version / build
          / changes and FAQ information.
          For novice users, we have a guide to help you through Rivatuner and setup fan speeds and overclocks on your graphics card. This guide will hopefully help you understand how to use the features that Rivatuner provides
            ตามกันมาติดๆ
              มาไวจิงๆ
                  คุงคราบ
