How do you delete contacts on iPhone if you want to remove them , i know what you are going to say , we can click the "delete" button to remove the contacts from iPhone,it sounds very fast and convenient
But ,have you ever think about why some deleted contacts can be restored back on iphone ? because the deleted contacts is not completely deleted from iPhone ,some people can ask for recovery tool help to restore deleted conatcts on iPhone ,
that is why the deleted contacts can be easy recovered on iPhone ,if we are going to delete iPhone contacts and without recovered back , the only thing we have to do is permanently remove the contacts from iphone ,"Permanently Delete"
in this way , the deleted contacts won't be back on iPhone ,of course , to complete this remove program , we have to ask for iPhone data eraser tool help , which can help us wipe contacts (other data ) from iPhone permanently,
The following is my method about iPhone contacts eraser
1.Download and install the eraer app on your computer
After the app is installed ,connect your iPhone and computer ,
2. Delete iPhone contacts permanently
You can control the eraser app on computer . so , you can select the contacts that you want to remove on iPhone ,
3. Erase All iPhone data
This is the most radical step you can take. It will erase contacts on your iPhone. So make sure you have backed up all important contacts. After that, go to Settings > General > Reset and tap "Erase all contacts and settings".
In this way , you will be able to remove SMS,photos,call history,music and other personal files .more,
How to remove iPhone photos
How to delete text from iPhone
How to wipe iPhone data
