เปลี่ยนบอร์ดใหม่แล้วขึ้น warning cpu power is equal or above 95w
- CPU Q9550
- Mainboard (775-VSL) INTEL G41-D3C
ข้อมูลจำเพาะของ (775-VSL) INTEL G41-D3C
Model
INTEL G41-D3C
CPU Support
Intel? Core?2 Quad Processor
Intel? Core?2 Duo Processor
Intel? Pentium? Dual-Core Processor
Intel? Celeron? Dual-Core Processor
Intel? Celeron? D Processor
Intel? Celeron? Processor 400 Sequence
Maximum CPU TDP (Thermal Design Power) : 95Watt
FSB
Support FSB 1333/1066/800/533MHz
RAM
Support Dual Channel DDR3 1333(OC)/1066/800 MHz
2 x DDR3 DIMM Memory Slot
Max. Supports up to 8GB Memory
Note: FSB800 CPU only support DDR3-800
Sound
ALC662 5.1 channel auto out High Definition Audio
LAN
RTL8105E 10/100 Mb/s auto negotion
PCIe 16x (at x16 mode)
1 Slot
PCI
1 Slot
PS2
Keyboard 1 Port
Mouse 1 Port
USB 2.0 back Panel
4 Ports
SATA
SATA2 x 2 Connector
VGA / D-Sub Port
VGA 1 Port
Serial Port (com1)
1 Port
Parallel Port (LPT)
1 Port
ดูจากสเปคน่าจะใส่ได้ครับ
รบกวนผู้เชี่ยวชาญหน่อยครับ
- CPU Q9550
Model
INTEL G41-D3C
CPU Support
FSB
RAM
Sound
LAN
1 Slot
PCI
1 Slot
PS2
Keyboard 1 Port
Mouse 1 Port
USB 2.0 back Panel
4 Ports
SATA
SATA2 x 2 Connector
VGA / D-Sub Port
VGA 1 Port
Serial Port (com1)
1 Port
Parallel Port (LPT)
1 Port
