windows 8.1 CPU ทำงาน 100%
  • windows 8.1 CPU ทำงาน 100%
    พอผมเข้าไปดู Task Manager ก็เจอ 3ตัวนี้ ที่ ทำงานอยู่ windows modules installer worker / service host local system (network restricted) / และ service host local system แก้ไขยังไงครับ
    In Windows 8 or 8.1 laptop, sometimes CPU fan run very fast and make noise because Windows Module Installer Worker occupies CPU more than 50%.
    In this case, you can solve the problem by changing windows update into manual mode.
    How to do it:
    Open services.msc (In Windows 8, WindowsKey+R and enter services.msc)
    Search "Windows module installer".
    Double click the "Windows module installer", and make it manual. It is usually set Automatic.
    Search "Windows update".
    Double click the "Windows update", and make it manual.
    Open Control panel (click the right button of your mouse at the lower left of you display monitor or LCD, e.g., at the Windows logo. and then you can see control panel menu)
    Click "Windows update"
    In left you can see "Change settings"
    Change the setting into "Check for updates but let me choose whether to download and install them". It is usually set automatic.
    Reboot
    The Windows module installer workers cannot bother you anymore.
    Important:
    Because Windows update is set manual, you MUST check regularly (weekly or monthly) windows update by yourself.
    Also, cleaning up your disk may help to reduce CPU usage by windows module installer worker
    423 people found this helpful
    credit:microsoft.com
    เข้าไปปิดการอัพเดทออโต้โดยเลือกเป็น "Check for updates but let me choose whether to download and install them" ตามที่เวปไมโครซอฟท์แจ้งน่าจะหมดปัญหาแล้วล่ะครับ
