เกิด bluescreen วันนึงประมาณ 2-3 ครั้ง ช่วยดูหน่อยครับ เกิดจากอะไรครับ
-fx-8150
-m5a88-m evo
-asus HD6850
-Ram G.Skill PC3-12800(800MHz) 2*4G
System Information (local)
computer name: AIRCAM-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD FX(tm)-8150 Eight-Core Processor AMD586, level: 21
8 logical processors, active mask: 255
RAM: 8572162048 total
VM: 2147352576, free: 1941143552
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Wed 10/30/2013 9
00 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\103013-29546-01.dmp
This was probably caused by the following module: rt64win7.sys (0xFFFFF8800447579E)
Bugcheck code: 0xD1 (0xFFFFF8800538E000, 0x2, 0x0, 0xFFFFF8800447579E)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\rt64win7.sys
product: Realtek 8136/8168/8169 PCI/PCIe Adapters
company: Realtek
description: Realtek 8136/8168/8169 NDIS 6.20 64-bit Driver
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rt64win7.sys (Realtek 8136/8168/8169 NDIS 6.20 64-bit Driver , Realtek ).
Google query: Realtek DRIVER_IRQL_NOT_LESS_OR_EQUAL
-fx-8150
-m5a88-m evo
-asus HD6850
Crash Dump Analysis
On Wed 10/30/2013 9
00 AM GMT your computer crashedcrash dump file: C:\Windows\Minidump\103013-29546-01.dmp
company: Realtek
