Easily and Fast Rip and Convert DVD and Video With Total Media Converter
  • Easily and Fast Rip and Convert DVD and Video With Total Media Converter
    With so many your favorite videos on your computer and with so many desired videos or music on your DVDs, do you want to enjoy them on your iPhone, iPad, iPod legally? Tipard Total Media Converter, as the best two-in-one Media Converter can do both of them: ripping DVD and converting video movies.
    Introduce this piece of software in brief. Tipard Total Video Converter can rip DVD to common video formats such as mp4, H.264, wmv, swf, mov, flv, avi, 3gp, mkv and convert video among mkv, mp4, avi, mov, wmv, flv, vob, swf, m4v etc..
    If you would like a try, the first thing is to download this program from here.
    Step 1.Click the "Add File" or ?Load DVD? button to add video file or DVD.
    Step 2. Video settings
    Select the output video format you want from the drop-down list of profile or subtitle or audio track.
    Note:
    By cicking the "Settings" button, you can set the video parameters and audio tract.
    step 3.Click the "Start" button to start conversion. It is very fast and in a short while your conversion will be finished.
    Tipard Total Media Converter has basically editing funtions such as snapshot, effect, trim, crop, watermark, merging clips into one file and extract audio from DVD and video files.
    Take some as examples:
    ?Watermark?
    By clicking ?watermark? you can add text or picture watermark for your video according to your need.
    ?Effect?
    Click ?Effect? button you can do these actions: adjusting brightness, contrast and saturation of the video. You can easily adjust the video through two windows in the same interface.
    ?Trim?
    If you just want convert a clip of your video, then you can use the "Trim" icon to set the Start time and End time of the clip or you can directly drag the slide bar to the accurate position.
    ?Crop?
    By using the ?Crop? function you can crop the black edge of your video and you can also drag the line around the video image to adjust your video to your Google Phone.
    For Mac Version : Total Media Converter for Mac
    Convert Mts
    Mac Mts Converter
    Mac Blu-ray Converter
