Popular Conversion Tools Among People
  • Popular Conversion Tools Among People
    Now iPod and iPhone have become main entertainment tool, so they take an important role in people?s life. Almost everyone has their lots of favorite DVDs in their hands, but the questions is iPod/iPhone can only accepts H.264 and MP4 video formats.
    Don?t worry. A professional DVD to iPod Converter and DVD to iPhone Converter can help you resolve this question.
    This guide shows you how to convert DVD to iPod/iPhone supported video formats. It includes two parts.
    Part 1: How to enjoy DVD on iPod Touch/Nano 3/Classic.
    Part 2: How to enjoy DVD on iPhone/iPhone 3G.
    Step 0: Download Tipard DVD to iPod Converter. The interface is seen as follows:
    Step 1: Load DVD.
    Click "Load DVD" to add your DVD contents..
    Step 2: Set output video format
    Click "Profile" button from the drop-down list to select the exact output video format that is the most suitable for your iPod. You can click the "Settings" button to set parameters of your output video such as such as Resolution, Video Bitrate, Frame Rate, Audio Channels, Sample Rate, etc. to get the best video quality as you want.
    Step 3: Click the "Start" button to start the conversion.
    Tips:
    1: How to join your selected chapters
    If you want to merge several chapters into one file you can choose them and click the "Merge into one file" to do it.
    2: How to split your video
    The "Trim" function also servers as a video splitter for you to get any time-length video episode. You can set the "Start Time" and "End Time" to set the time of the clip or you can directly drag the slide bar to the accurate position.
    3: How to crop off the black edges and adjust the size of video play region
    By using the "Crop" function you can crop the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices.
    4: How to save your favorite picture
    If you like the current image when preview video, you can use the "Snapshot" option. Just click the "Snapshot" button the image will be saved and you can click the "Open" button next to "Snapshot" button to open your picture.
    Step 0: Download and install Tipard DVD to iPhone Converter.
    Step 1: Run this DVD to iPhone Converter and load your input DVD files.
    It allows you to load DVD, Load DVD Folder and Load IFO File.
    Step 2: Set up the output profile and the output file path.
    Tipard DVD to iPhone Converter can convert DVD into iPhone MP4, MOV, H.264 video formats and iPhone audio MP3, M4A, AAC, WAV.
    This converter provides more video and audio parameters for you to get the perfect video quality for your player. Click ?Settings? button to set it.
    Click ?Browse? to choose the path for you to save the converted file.
    Step 3: Start conversion
    After you set all the settings, you can click ?Start? to start conversion.
    Tips:
    Some powerful and professional editing functions are also available such as effect, trim, crop and so on. You can refer to the tutorial of Tipard DVD to iPod Converter above.
    Recently Tipard Studio has released Tipard iPod Transfer Platinum . The Pro version has more functions and more powerful. Besides Tipard iPhone Transfer Platinum are also available now.
