Originally posted by Jet1986
ผมก็คิดว่ามันไปเอาเสียงของ AV มาใช้ได้ แต่เอาภาพของ VGA น่ะครับ ผมก็นั่งเสียบอยู่นั่นล่ะ ทำไมเสียงไม่ยอมออก มาดูคู่มือ มันว่าถ้าต่อ VGA ต้องต่อเสียงด้วยช่อง PC Aduio ซึ่งเป็น Jack 3.5 mm
อ้างอิงค์จากเว็บนี้
How to Connect a PC to a Samsung LCD TV
A Samsung LCD television can be used as a primary monitor for a PC. This is convenient for people who wish to use their PC to watch movies or do light Internet browsing from the comfort of their couch. Samsungs and most other new LCD TVs have a "PC input," which is actually just a standard VGA input. VGA cables connect your PC to a monitor, so if you already have one, you most likely have the cable.
Things You'll Need
- VGA cable
- 3.5 mm audio cable
1.Connect the VGA cable to your computer's "VGA out" port, usually designated by a blue color. Connect the 3.5 mm cable to the "audio out" port, usually designated by a headphone symbol or by being green.
2.Connect the other end of the VGA cable to the "PC Input" port on the back of your Samsung TV. It will be labeled as such. Connect the other end of the 3.5 mm audio cable to the hole directly underneath the place where the VGA cable is connected.
3.Turn on the computer and the television. Go to your input options and select "PC." Your computer should now be using the television as a monitor.
