Are you still bothered by how to convert your Blu-ray files and common DVD to any other video and audio formats such as MP4, AVI, WMV, MKV, FLV, SWF, and even HD video, or with what kind of tool to convert any video to the video formats you need? The Blu-Ray Ripper is coming to help you solve the problems when converting Blu-ray files and common DVD.
Here I?d like to introduce the powerful and strong functions of this Blu-ray Ripper, and if detailed information will be found on the Blu-ray Ripper Review about the Windows Blu-ray Ripper.
Rip Blu-ray and DVD to any Video and Audio
With this ble-ray ripper, you can convert any Blu-ray video, common DVD, and any other video formats to the formats you want with dramatically fast speed and high sound and image qualities.
Various output formats including MP4, AVI, WMV, MKV, FLV, SWF, and even HD are supported by it.
Remove Copy Protections
This Blu-ray Ripper can remove the copy protections easily including the protections that are newly published.
Powerful Editing Functions
In order to make the output files perfect and unique, you can customize them through the powerful editing functions.
1) Trim Videos: Just by moving your mouse to set the beginning and ending part of the video you want to clip, you will get the trimmed video easily.
2) Crop Videos: With this function, you can remove the backdrop and blackboards of the videos.
3) Merge Videos: If you want to merge r several clips of different videos into a single one, you can merger them together.
4) Add Watermark: Texts or images can be added to the videos to make your output files unique and special.
5) Adjust Video Effects: The video brightness, contrast, saturation, hue and volume can be changed to get the ideal effects.
Preview and Snapshot
Both the original and converted videos can be previewed to help you make comparison; you can capture one certain scene of a video to keep it as image forever.
This Blu-ray Ripper is really excellent software. Once you use it, you will know its magic power to converting BD, DVD or any other video formats to the formats you need. And if you are a Mac user, check more information on Blu-ray Ripper for Mac.
Please do not hesitate to try it.
