My elder sister is fond of movies, but she is always bothered by the problems that her video player is not compatible with different kinds of video formats except the MP4 format. She is keen to find a video converter which can help her convert video formats as easily as possible. I recommended the Aiseesoft Total Video Converter to her , which is beneficial for her to solve her problems.
It is very convenient for you to convert the original format to the formats you want. You just need to click the Add Video button to add audio and video files to the converter.
Choose one file you want to convert and then click the Profile buttonto to ide your wanted format. Also, adjusting and saving the settings of your output profiles is available. Then you can get your wanted video formats by clicking the Convert button.
In addition, this video converter offers some extra powerful functions for you to edit your audio and video files such as adjusting effects, trimming effects, cropping effects and editing watermark.
To Adjust Effects
You can change the Brightness, Contrast, Saturation and Hue at will.
To Trim Files
To drag the slider stopping at any part you want or setting the Start time and End time is OK.
To Crop Files
You can adjust the video size to get what the screen size your desired size. A yellow frame and eight small boxes can be seen on the ?Original Preview?; by dragging the boxes you can see the cropped results on the ?Output Preview?. Also, you can crop by setting the values in the Left, Right, Top, and Bottom area.
To Edit Watermark
Check the Enable Watermark button to edit watermark. You can type your wanted text and add pictures. The position and transparency of the watermark can also be adjusted on the screen.
Using the Aiseesoft Total Video Converter is the easiest way to convert video formats and it is absolutely your best choice. After experiencing it, my sister said it was really perfect and fantastic.
Mac users, do you have any problems when you are converting videos? We also have the Aiseesoft Video Converter for Mac for you. Please do not hesitate to try it.
To Adjust Effects
To Trim Files
To Crop Files
To Edit Watermark
