The latest Sony, Panasonics and Cannon HD camcorder are using MTS/M2TS for saving recordings. Since the MTS video format is for the HD camcorders, and the portable multimedia devices do not support playing the M2TS video directly, if we want to play the MTS videos on the portable device we need an additional video converter tool. Aneesoft MTS to AVI Video Converter is such a video converter which can help users convert MTS to AVI videos.
This article shows a step-by-step guide to convert MTS to AVI videos with Aneesoft MTS to AVI Video Converter. Follow our guide and try now!
Things youll need
1. Aneesoft MTS to AVI Video Converter (Free for download trial version)
2. MTS video files
Step 1: Download the Aneesoft AVCHD Video Converter. Install and run it.
Aneesoft MTS to AVI Video Converter is a perfect and versatile MTS file converter that armed with a user-friendly interface and fast speed, it makes MTS to AVI conversion routine quite simple. head over here and download the free trial version. Next step is to install the program.
Step 2: Import MTS video to MTS to AVI Video Converter
First copy the AVCHD (.MTS,M2TS) file from your video camera to your hard drive. then install and run Aneesoft MTS to AVI Video Converter, Click the "Add..." button to add the AVCHD videos which you want to convert, you may add as many videos as you want to convert to AVI videos.
Step 3: Edit MTS videos to improve the output quality (Optional)
After importing AVCHD MTS/M2TS videos, please click "Edit" button to access to the Video Edit panel. To personalize your video, You can also try to add picture or text watermark with customized transparency, size and position in your videos.
Step 4: Merge MTS videos to 1 single file (Optional)
This is optional. But if you want to output 1 single file for easily playing on your portable device, simply click on the video titles you'd like to merge , then click 'Merge' button and uncheck the former separate files if you just need the single merged video file. You may see the image below to have an idea.
Step 5: Change the output settings to convert MTS to AVI videos with best quality
Select AVI format from the output formats list in "general video" drop-down list.and specify a directory on your computer to save the output files. You can change the output settings as you need. Remember that the output file size mostly depends on the Bitrate you set. Larger Bitrate, larger file size.
Step 6: Hit "Convert" to start the MTS/M2TS to AVI conversion
Click "Convert" button to start converting MTS files. Aneesoft MTS to AVI Video Converter (link5) runs fast in MTS/M2TS to AVI conversion, taking advantage of its support for batch and multiprocessing. It is clear to see the progress with estimation of remaining time on display.
You may be interested in these topics:
How to embed YouTube video to PowerPoint
How to convert YouTube to iPad
How to convert AVI to WMV videos
How to convert MP4 to AVI videos
How to convert MKV to XviD videos
How to convert MKV to MPEG videos
How to convert DVD to iPad video format
How to convert DVD to iPhone video format
How to rip DVD to BlackBerry video format
How to convert DVD to MOV video format
How to convert DVD to PS3 video format
How to convert DVD to WMV video format
How to rip DVD to PSP video format
How to convert HD video for your portable video player
How to convert video to iTunes format for free
Things youll need
2. MTS video files
