WMV video converter-How to Convert Mp4, MOV, VOB video to WMV
  • WMV video converter-How to Convert Mp4, MOV, VOB video to WMV
    I have a large collection of MP4, MOV or VOB videos and now I always need to add them into Windows Movie Maker for editing. But the Windows Movie Maker doesn’t support these formats. I have to convert them to WMV format, which is compatible with Windows Movie Maker. One of my friends recommended me a video converter tool which called Aneesoft WMV Video Converter.
    Aneesoft WMV Video Converter is the best video to wmv converter which designed to meet all your needs of converting files from AVI, MPG (MPEG), MP4, MOV, VOB, ASF, RM, RMVB, 3GP, 3G2 to WMV files. Extremely fast conversion speed and friendly user interface allows you to convert video files to WMV format with ease.
    It also has useful function making your converted videos more personal. You can trimming video, converting video clips, taking a snapshot, edit video with trim, crop, merge function, and even add watermark and special effects to video. Besides converting videos formats to WMV formats, it also allows you to extract audio files from your videos.
    Things you’ll need
    1. Aneesoft WMV Video Converter (Free for download trial version).
    2. MP4, MOV, VOB video files.
    Step 1: Download & install Aneesoft WMV Video Converter
    We’ll be using the very nice video converter software called Aneesoft WMV Video Converter for converting videos to WMV video format, head over here and download the free trial version of Aneesoft WMV Video Converter. Next step is to install Aneesoft WMV Video Converter.
    Step 2: Run Aneesoft WMV Video Converter and add videos
    Now run Aneesoft WMV Video Converter and click the big button "Add..." to add videos from your hard disk, you may add as many videos as you want to convert to WMV video format. Only the titles you checked will be converted.
    Step 3: Edit & merge videos: trim, crop, add effect, add watermark
    You're able to make your video personalized with Aneesoft WMV Video Converter if you want. Firstly, you should click on the button "Edit" to lauch the built-in video editing tool. And then you may find lots of features available for you to make the videos be your own style, such as crop, trim add watermark, etc. For example, if you want to add effect to your videos, you need to check the box "Enable Effect" and set the contrast & brightness.
    Notices: Aneesoft WMV Video Converter program has two versions. The free version-Aneesoft Free WMV video converter is function-limited. If you’d like to edit and merge your videos, you need to upgrade to the pro version.
    Step 4: Set the output WMV video format
    The fourth step before conversion is to set the output format. Select WMV profile by a click. You should notice that the output file size mostly depends on the bitrate you have set. Larger bitrate, larger file size.
    Step 5: Start converting Mp4, MOV, VOB videos to WMV video format
    Now you may click the big button "Start" to begin converting videos to WMV video files. Once the convert is complete, Aneesoft WMV Video Converter will place on your Desktop a new WMV version of your video that can be imported into Windows Movie Maker. Double-click the new file and play it to make sure it looks as you expect. I bet you’ll be surprise at the video quality, just like me.
    You may be interested in these topics:
    How to convert YouTube to iPad
    How to convert AVI to WMV videos
    How to convert MP4 to AVI videos
    How to convert MKV to XviD videos
    How to convert MKV to MPEG videos
    How to convert DVD to iPad video format
    How to convert DVD to iPhone video format
    How to rip DVD to BlackBerry video format
    How to convert DVD to MOV video format
    How to convert DVD to PS3 video format
    How to convert DVD to WMV video format
    How to rip DVD to PSP video format
    How to convert HD video for your portable video player
    How to convert video to iTunes format for free
    ทำเพื่อ ไรครับ เห็นเยอะจังครับ กระทู้แบบนี้ผิดหมวดแบนใหเรียบไอ้พวกนี้
