An ordinary DVD movie is often 7-8 GB in size, if we convert them to ordinary video formats, the size would be hundreds of MB, so, we have to face this problem that the code compress process would destroy most of unimportant data and the video quality get bad. How do we resolve this issue? We can decrease the damage by converting DVD to MKV HD video formats.
An MKV HD video file is a Matroska file, the Matroska Multimedia Container is an open standard free Container format. It is similar in conception to other containers like AVI, MP4 or ASF, but is entirely open in specification, and the size is often much bigger than common video for the HD code methods.
Here I recommend Aneesoft DVD to MKV Video Converte for Mac which is the most easy-to-use one that I have ever used. I love the fast speed of the conversion and the high customization, which fully satisfy my needs. So, let's go to learn how to convert DVD to MKV step-by-step with Aneesoft DVD to MKV Video Converter.
Things youll need
1. Aneesoft DVD to MKV Video Converter for Mac (Free for download trial version).
2. DVD video files.
Step 1: Download Aneesoft DVD to MKV Video Converter and run it
First of all, we need to download Aneesoft DVD to MKV Video Converter for Mac. With which we can see no quality lost from the original DVD, that is absolutely what we want. After we install it to computer, double click to run this nice software. Notice, if your computer runs windows OS, please download the Windows version.
Step 2: Add DVD video files to Aneesoft DVD to MKV Video Converter
Okay, since we have run Aneesoft DVD to MKV Video Converter to launch the straightforward interface. We can click the button "Load..." to add DVD videos. The DVD movie will be seperated to several chapters when loaded in, this makes it easy for you to remove the titles and background, you can just select the most wonderful segment of this movie to convert to MKV videos.
Step 3: Edit DVD videos: crop, add effect, add watermark and so on
With a simple click of the button "Edit" on Aneesoft DVD to MKV Video Converter for Mac to launch the editing window, you can make your movie very personalized. To crop your DVD videos to set up your figures of crop area and aspect ratio, add effect to set the contrast and brightness, even some artist effects. Morever, you can also add watermarks to your movies, either an image or a text.
Step 4: Set the MKV output to convert DVD to iPad
Select the MKV formats we'd like to convert. What you should know is that different presets for different levels of quality or file size, the larger bitrate you set, the larger file size you will get.
Step 5: Start converting DVD to MKV videos
Click the big button "Start" to begin our converting of DVD to MKV videos.The converting time will mostly depend on some several factors, such as the speed of your computer, the bitrate you have set and what other things your computer are currently doing.
You may be interested in these topics:
How to embed YouTube video to PowerPoint
How to convert YouTube to iPad
How to convert AVI to WMV videos
How to convert MP4 to AVI videos
How to convert MKV to XviD videos
How to convert MKV to MPEG videos
How to convert DVD to iPad video format
How to convert DVD to iPhone video format
How to rip DVD to BlackBerry video format
How to convert DVD to MOV video format
How to convert DVD to PS3 video format
How to convert DVD to WMV video format
How to rip DVD to PSP video format
How to convert HD video for your portable video player
How to convert video to iTunes format for free
Things youll need
2. DVD video files.
