The day of the last birthday, my friend invited me to have a wonderful bungee jumping; it’s really a amazing experience. They captured the process of my jumping with Panasonic DMC-G1. I just can’t help sharing the videos with my friends. But there is a question; the video existed in .mts files--a format most media players and video-editing programs don’t recognize.
So I Google it, and the definition is like this: High-definition MPEG Transport Stream video format, commonly called “AVCHD” used by Sony, Panasonic, and other HD camcorders; based on the MPEG-2 transport stream and supports 720p and 1080i HD video formats.
AVCHD stands for “Advanced Video Codec High Definition”. The format was jointly established by both Panasonic and Sony in 2006. MTS files can typically be opened and edited using the software included with Sony and Panasonic HD camcorders.
I want to enjoy it with my iPod touch, so maybe the best way for me to do is to find a MTS Converter to help me.
MTS Video Converter is fast MTS file converter to convert HD video to general video, convert general video to HD video, convert among HD videos, such as MTS to AVI , MTS to MP4 , MTS to WMV , MTS to FLV , MTS to MP3 or convert MTS files to, DivX, XviD, ASF , MKV, SWF, VOB video format or AAC, AC3, OGG, WAV, WMA audio formats to let you enjoy MTS video as your preference.
Now just follow me to learn how to convert MTS to iPod.
Download MTS to iPod Converter and install it successfully, you will see the interface as follow, what’s more, the steps in it will help you a lot to use.
Step 1: Add File
Click “Add File” to add MTS videos to prepare for converting.
Step 2: Set Profile
Select the category from the first drop-down list as iPod and select the output formats from the next one which are all supported by iPod device.
Step 3: Set output folder
The simplest way to choose destination is clicking “Browse”.
Step 4: Convert MTS to iPod
Click “Start” to convert MTS to iPod for the iPod fans.
MTS to iPod Converter will be the best choice for the iPod fans to convert MTS to MP4 to iPod without any losses and then you can enjoy MTS videos on your iPod device.
Hint: There are limitations for free trail that a more than 5 minutes file can only be converted 5 minutes, while a less than 5 minutes file can only be converted half, so you need register it if you want to enjoy full functions.
If you’re Apple Mac computer users, you can try Mac MTS Converter to start your wonderful experience.
Step 1: Add File
Step 2: Set Profile
