How to Convert Video to iPad in Easiest Way
  • How to Convert Video to iPad in Easiest Way
    What is an iPad?
    The iPad is the first tablet computer developed by Apple Inc. There are two models for iPad,including Wi-Fi and Wi-Fi+3G.Its exactly in bteween a smartphone and a laptop,it works like a hybrid between an iphone and a full laptop.The operating system is a modified version with a user interface redesigned to take advantage of the large screen and will look just as crisp as they would on a normal computer.
    Height: 9.56inches(242.8mm)
    Width: 7.47inches(189.7mm)
    Depth: 0.5inch(13.4mm)
    Weight: 1.5pounds(.68kg) for Wi-Fi and 1.6pounds(.73ke) for Wi-Fi+3G
    Screen Size: 9.7inches diagonal(1024x 768resolution)
    10 hours of active use on a single charge, or 30 days in standby mode.
    Like the older iPod Touch and iPhone devices, the larger iPad runs the iPhone OS operating system and uses a multi-touch LCD display for most user interactions. It runs iPad-specific applications as well as ones written for the iPod touch and iPhone, including e-book readers.
    The iPad uses wireless connections — WiFi or a 3G cellular network — to browse the internet, load and stream media, and install software.
    From above we know that iPad gives you more convenient to experience the web, email, photos and videos. The iPad has a 10-hour battery life, for movies fans, to enjoy movies with a long battery life device is nice thing on a long air, bus or train boring trip. The 9.7-inch high-resolution screen makes iPad perfect for watching HD movies, TV shows, podcasts, music videos, and more.
    Do you like watching the latest movies? Do you want to enjoy Iron Man 2 with the 9.7-inch high-resolution screen iPad? Now don't hesitate to try this iPad Video Converter.
    If you are a beginner who are worried about this problem that How to Convert video to iPad, the following content is helpful for you. Also if you are so skilled in converting video to play on iPad, you can see if this iPad Video Converter is easier to operate or not. Whatever, I hope the following content is helpful for you.
    Preparation: Click the "Download" button to free download this professional iPad Video Converter and double click the .exe file to install it on your PC.
    Step 1: Load the video files by clicking the "Add File" or "File>Add File" button.
    Step 2: Click the "Effect","Trim","Crop","Merge" button to set your personalized output effects like: Brightness, Contrast, Saturation, etc.
    Step 3:Click the "down arrow" button to set the output format and click the "Browse" button to set the destination folder. You can get your output video files from "Open Folder".
    Step 4: Click the "Convert" button to start Converting video to iPad. Before you convert video files, you can preview the files added and capture your favorite pictures just by this button.
    Now you can just wait a few minutes to enjoy the video on your iPad happily. Just go to have a try now. Good luck.
    iPad Converter
    iPad Transfer
    DVD to iPad Converter
