ไอ้ตัวเนี่ย มันอัดแรม bus400 ได้ 4G ใช่ปล่าว
MAINBOARD SOCKET775 ของ ASRock รุ่น 775V88+ ChipSet VIA PT880
Features :
Supports LGA775 FSB800/533MHz processor, Intel EM64T-enabled processors and H-T Technology
Intel 04B/04A processors compatible
Supports DDR400 and Dual Channel Technology
Hybrid Booster - ASRock Safe Overclocking Technology
SerialATA 1.5Gb/s, SATA HDD_Hotplug, RAID 0,1,JBOD
AGP8X, 5.1channel Audio, 10/100 Ethernet LAN
ASRock I/O Plus: 6 ready-to-use USB2.0 port
ASRock รุ่น 775V88+ Specifications
BIOS :
2Mb AMI BIOS with ACPI, SM BIOS 3.0, PnP
PROCESSOR :
LGA775 for Intel Pentium 4/Celeron processor
FSB 800/533 MHz
Support advanced Intel EM64T CPU
Supports Hyper-Threading Technology
CHIPSET :
Northbridge: VIA PT880
Southbridge: VIA 8237
HYBRID BOOSTER :
CPU Frequency Stepless control
ASRock U-COP
Boot Failure Guard (B.F.G)
MEMORY :
Dual Channel DDR memory technology
Supports DDR400/333/266
DIMM slots: 4
Max. capacity: 4GB
EXPANSION SLOTS :
1 x AGP8X/4X slot, 1.5V
5 x PCI slots
AUDIO :
CMedia CMI9761 6 channel AC'97 audio codec
LAN :
VIA 6103 10/100 Ethernet LAN PHY
802.3u, WOL supported
CONNECTOR :
2 x SeialATA 1.5Gb/s connectors, supports RAID,0,1,JBOD, SATA HDD_Hotplug
2 x ATA 133/100/66 IDE connectors ( supports 4 x IDE devices)
1 x Floppy connector
CPU/Chassis FAN connectors
20 pin ATX power connector
4 pin +12V ATX power connector
IDE LED connector
CD/AUX audio in header
Front panel audio connector
2 x USB 2.0 port pin header
REAR PANEL I/O :
6 x USB2.0 ports 1 x RJ45 LAN port
1 x Serial port (COM1)
1 x PS2 Keyboard connector
1 x PS2 Mouse connectors
1 x Parallel port (LPT1)
1 x Audio port ( Line In/Out, Mic In)
FORM FACTOR :
ATX, 305mm x 244mm
Features :
BIOS :
PROCESSOR :
FSB 800/533 MHz
CHIPSET :
HYBRID BOOSTER :
ASRock U-COP
MEMORY :
DIMM slots: 4
Max. capacity: 4GB
EXPANSION SLOTS :
5 x PCI slots
AUDIO :
LAN :
CONNECTOR :
IDE LED connector
REAR PANEL I/O :
FORM FACTOR :
ATX, 305mm x 244mm
