อยากทราบว่า เมนบอร์ดตัวนี้ มีประสิทธิภาพดีรึเปล่าครับ เหมาะสำหรับใช้เล่นเกมหนักๆ กับ Oc ได้รึเปล่าครับ พอดีใช้ตัวนี้อยู่ครับ ถ้าไม่ดีจะได้ซื้อใหม่ ช่วยชี้แนะด้วยครับ
CPU
LGA775 socket for Intel® Pentium 4/Celeron CPU
Compatible with Intel® 6XX, 5XX and 3XX processors
Intel ®Hyper-Threading Technology ready
Supports Intel® Enhanced Memory 64 Technology(EM64T)
Supports Enhanced Intel SteepStep® Technology(EIST)
Intel new next generation CPUs enabling ( subject to Intel CPU availability and NVIDIA chipset supportability )
Chipset nVIDIA nForce4 SLI - Intel Edition ( Crush 19 )
nVIDIA MCP-04
Front Side Bus 1066 / 800MHz
Memory Dual channel memory architecture
4 x 240-pin DIMM sockets support
max. *8GB / 4GB DDR2 667/533/400 non-ECC memory ( 8GB DDR2 support for 64 bit OS platform only )
Native DDR2 720 support
Expansion Slots 2 x PCI Express x16 slot
- SLI mode : x8 , x8
- Normal (Single VGA) mode : x16, x1
2 x PCI Express x1
3 x PCI
SLI Under SLI mode : support two identical SLI-ready graphics cards
Under Default(Single VGA) mode: supports all PCI Express graphics cards
ASUS EZ Plug
ASUS SLI Status LED
ASUS EZ Selector
ASUS two-slot thermal design
ASUS PEG Link for dual PCIe graphic cards
Storage/RAID nForce4 Storage:
- 4 x SATAII
- 2 x UltraDMA 133/100/66/33
- NVRAID : RAID0, RAID1, RAID 0+1, Software RAID 5 and JBOD span cross SATA and PATA
Silicon Image 3132R RAID controllers :
- 2 x SATAII
- RAID 0, 1 and exteral SATA connectability
LAN nForce4 built-in Gbit MAC with external Marvell PHY :
- NV ActiveArmor
- NV Firewall
- AI NET2
Intel PCI Gbit LAN controller
Audio Realtek ALC850, 8-channel CODEC
Audio Sensing and Enumeration Technology
Coaxial/Optical S/PDIF out ports on back I/O
IEEE 1394 TI 1394 controller supports 2 x 1394 ports
USB Max. 10 USB2.0 ports
ASUS AI Proactive Features AI NOS â„¢(Non-delay Overclocking System)
Precision Tweaker
PEG (PCI Express Graphics) Link Mode
Fanless Design
AI NET2 network diagnosis before entering OS
Overclocking Features CPU Lcok Free
AI NOSâ„¢ (Non-delay Overclocking System)
AI Overclocking (intelligent CPU frequency tuner)
ASUS PEG Link for single/dual graphics cards
Precision Tweaker:
- vDIMM: 9-step DRAM voltage control
- vCore: Adjustable CPU voltage at 0.0125 increment
- SFS (Stepless Frequency Selection): allowing FSB tuning from 200MHz up to 400MHz at 1MHz increment
- PCIe Frequency: allowing PCIe frequency from 100MHz up to 200MHz at 1MHz increment
Fixed PCIe/PCI frequencies.
ASUS C.P.R.(CPU Parameter Recall)
Other ASUS Special Features CrashFree BIOS 2
Q-Fan2
1 x PS/2 Mouse
Multi-language BIOS
MyLogo2
BIOS 4 Mb Flash ROM, AWARD BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3
Back Panel I/O Ports 1 x Parallel
1 x Optical + 1 x Coaxial S/PDIF Output
1 x PS/2 Keyboard
1 x PS/2 Mouse
2 x RJ45
4 x USB 2.0/1.1
1 x External SATA
1 x IEEE1394
8-Channel Audio I/O
Internal I/O Connectors 1 x SLI selector card connector
3 x USB 2.0 connector supports additional 6 USB 2.0 ports
1 x IEEE1394 connector
1 x COM connector
1 x GAME/MIDI connector
CPU Fan / 2x Chassis Fan/ Power Fan/ Chipset Fan connectors
Front panel audio connector
Chassis Intrusion connector
CD audio-in connector
24-pin ATX Power connector
4-pin ATX 12V Power connector
4-pin EZ Plug power connector
Support CD Drivers
InterVideo WinDVD Suite (OEM version)
ASUS PC Probe - PC Health Monitoring Software
ASUS LiveUpdate Utility
ASUS AI Booster
NVIDIA nTune Utility
Anti-virus software (OEM version)
Form Factor ATX Form Factor, 12"x 9.6"(30.5cm x 24.5cm)
CPU
nVIDIA MCP-04
2 x PCI Express x1
3 x PCI
ASUS EZ Plug
ASUS SLI Status LED
ASUS EZ Selector
- 4 x SATAII
- 2 x SATAII
- NV ActiveArmor
- NV Firewall
- AI NET2
Precision Tweaker
Fanless Design
Precision Tweaker:
Q-Fan2
1 x PS/2 Mouse
Multi-language BIOS
MyLogo2
1 x PS/2 Keyboard
1 x PS/2 Mouse
2 x RJ45
4 x USB 2.0/1.1
1 x External SATA
1 x IEEE1394
8-Channel Audio I/O
1 x COM connector
Support CD Drivers
ASUS AI Booster
