NOX Urano ll 530W
Form size: ATX/BTX Standard
Power: 530W
Input power: 115/230 Vac
10.7A/6.2A
Frequency 50/60Hz
Output power: +3.3V: 23A
+5V: 28A
+12V1: 17A
+12V2: 18A
-12V: 0.6A
+5VSB: 2.0A
Output connections: 1x 20/24pin MB
1x 12V 4+4pin CPU
4x SATA
5x 4pin peripherals
1x 6pin PCIe
1x FDD
PFC: Passive
Cooling: 140mm smart fan with automatic speed
Noise level: < 21dBA
Protections: Over voltage; under voltage; overload; short circuit
Dimensions: 85 (H) x 150 (L) x 163 (D) mm
Extra features: - Passive PFC
- 140mm smart fan with automatic speed
- SATA connectors
Raidmax 530w
Type: ATX Form Factor 12V v2.2/EPS12V
Maximum Power: 530W
Input Current: 10A/5A
Output: +3.3V@28A, +5V@34A, +12V1@20A, +12V2@17A, -12V@0.8A, +5VSB@2.5A
Connectors:
1x Main connector (20+4Pin)
1x 12V (4-Pin)
6x Peripheral
2x Floppy
4x SATA
2x PCIe
Features:
Dual 12V output circuits provide added system stability
Huge 135mm Silent Blue LED Fan
Durable black stain finish
MOSFET Solid Capacitors
Hexflo honey comb cutouts for maximum airflow
High grade black mesh wrapped cabling
Komodo Smart Modular cabling system
Power Material: Stained Black SECC Steel
Warranty: 3 Years
Package: Retail
จะมาใช้คู่กับการ์ดจอ HIS HD 4850 ไม่รู้ว่าเอาตัวไหนดี เห็นของใหม่ แล้วจิตใจไขว้เขว
ปล. ใครพอจะอ่านออก ช่วยเปรียบเทียบความแตกต่างให้ด้วยก็ดีนะครับ ขอบคุณครับ
Power: 530W
10.7A/6.2A
Frequency 50/60Hz
+5V: 28A
+12V1: 17A
+12V2: 18A
-12V: 0.6A
+5VSB: 2.0A
1x 12V 4+4pin CPU
4x SATA
5x 4pin peripherals
1x 6pin PCIe
1x FDD
PFC: Passive
- SATA connectors
Raidmax 530w
Maximum Power: 530W
Connectors:
1x 12V (4-Pin)
6x Peripheral
2x Floppy
4x SATA
2x PCIe
Features:
Warranty: 3 Years
Package: Retail
เซ็ง!
