For Windows and Mac users, this article is aimed at showing you how to easily rip and edit your dvd movie, what you need is Tipard DVD Ripper and Tipard DVD Ripper for Mac.
Now the following 2 parts will show you how to use the software above.
Part 1: How to rip DVD and edit DVD on Windows
Make preparation: Download and install Tipard DVD Ripper
Step 1: Click "Load DVD" button to load your DVD.
This professional DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
Step 2:Select the output video format you want from the "Profile" drop-down list.
By cicking the "Settings" button, you can set the video and audio parameters. And this DVD Ripper also enables you to select *Audio Track, Subtitle*
Step 3:Click the "Start" button to begin your conversion.
You can have a coffee or have a walk now ! In a short while the conversion will be finished.
Some powerful editing functions such as "Trim, Crop, Effect, Merge, Snapshot" are also available.
*Watermark*
By clicking "watermark" you can add text or picture watermark for your video according to your need.
*Effect*
Click "Effect" button you can do these actions: adjusting brightness, contrast and saturation of the video. You can easily adjust the video through two windows in the same interface.
*Trim*
If you just want convert a clip of your video, then you can use the "Trim" icon to set the Start time and End time of the clip or you can directly drag the slide bar to the accurate position.
*Crop*
By using the "Crop" function you can crop the black edge of your video and you can also drag the line around the video image to adjust your video to your Google Phone.
Part 2: How to rip DVD and edit DVD on Mac
Make preparation: Download and install Tipard DVD Ripper for Mac
Step 1: Click the "Load DVD" button, find the DVD folder of the movie you want to add from your DVD-ROM, and Click "Open".
Step 2: Select the output video format you want from the "Profile" drop-down list.
Click "Settings" to set the exact video and audio parameters to meet your need.
Step 3: Click "Start" button to start your conversion
The conversion will be finish soon when you enjoy your leisure time.
The basic editing funtions such as "Merge, Effect, Trim, Crop, Snapshot" is also very powerful.
You will love to use it after you have a try!
*Watermark*
*Effect*
*Trim*
*Crop*
