How to rip DVD and convert video and burn a DVD
  • How to rip DVD and convert video and burn a DVD
    Our digital life has been much more enriched after the first DVD was released.But few people can make a full use of them.Here I'd like to share with you some skills to help you enjoy the digital world more easily.
    1.With Best DVD Ripper software-Aiseesoft DVD Ripper to rip your DVDs
    2:With Best Video Converter-Aiseesoft Total Video Converter to convert your videos on your portable players anywhere and anytime
    3.With Cucusoft DVD/VCD/SVCD Creator Pro to burn a DVD and make the effect as your will
    The following are the guides to show you how to achieve these goals.
    Part 1.How to rip a DVD
    Step 1: Install and run Aiseesoft DVD Ripper.
    Step 2: Click “Load DVD” button to load your DVD.
    This professional DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
    Step 3:Select the output video formats you want from the “Profile” drop-down list.
    Then you can click the start button to begin the conversion
    Also you can edit your video:
    1: Capture your favorite picture.
    Just click the “Snapshot” button the image will be saved and you can click the “File” next to “Snapshot” button to open your picture.
    You can select the destination of the picture by clicking the “Preferences” button. As default the captured image will be saved at:
    C:\Documents and Settings\Administrator\My Documents\Aiseesoft Studio\Snapshot
    2: Merge videos into one file.
    Just check the “merge into one file” option if you want to merge the selected contents into one file As default the merged file is named after the first selected file (either a title or a chapter)
    3: Video Effecting
    Click the “Effect” button and a dialog pops up, you can set your video effect here.
    Brightness: Drag and click the Brightness adjustment bar to set the brightness of the video.
    Contrast: Drag and click the Contrast adjustment bar to set the contrast of the video.
    Saturation: Drag and click the Saturation adjustment bar to set the saturation of the video.
    Volume: Drag the Volume adjustment bar to set the volume of the audio.
    4: Crop video
    You can crop the video by selecting a crop mode or setting the crop values
    There are four crop values on the lower right part of the crop window: Top, Bottom, Left and Right. You can set each value to crop your movie video, and the crop frame will move accordingly.
    Note: Before you start to crop your movie video, you can select an output aspect ratio from the Zoom Mode. There are four choices available: Keep Original, Full Screen, 16:9 and 4:3. After you select an output aspect ratio and finish the crop, the result can be previewed in the Preview window of the program main interface.
    Share more: Aiseesoft DVD Ripper can rip your DVD to almost any video formats supported by iPod Classic, iPod Touch, iPod Nano 4, PSP, iPhone (3G), iPhone, Zune, Zune 2, Blackberry, Nokia, Creative Zen, Sony Walkman, iRiver PMP, Archos, PS3, Apple TV, Xbox, iPAQ, Pocket PC, Mobile Phone, etc.
    Part 2.How to convert a DVD
    Step 1: Install and Run Aiseesoft Total Video Converter and then click “Add File” button to add your video.
    Step 2. Output format and Settings
    From the “Profile” drop-down list you can find one format that meets your requirement.
    To have your own video settings you can click “settings” button.
    After doing the 2 steps above, you can click “start” button to start conversion.
    Tips:
    1. Snapshot and merge into one file
    If you like the current image of the video you can use the “Snapshot” option. Just click the “Snapshot” button the image will be saved and you can click the “Open” button next to “Snapshot” button to open your picture.
    If you want to make several files output as one you can choose “Merge into one file”.
    2. Trim
    There are 3 ways that you can trim your video.
    a. You can drag the buttons(1) to set the start and end time
    b. You can preview the video first and when you want to start trim click the left one of the pair buttons(2) when you want to end click the right one.
    3. Crop
    There are 3 ways that you can crop your video.
    a. We provide 7 modes on our “Crop Mode”(1)
    b. You can set your own mode on the right side of the pop-up window(2)
    c. You can drag frame to set your own crop mode(3)
    Part 3.How to burn a DVD
    Step 0: Download Cucusoft DVD/VCD/SVCD Creator Pro, install and run it.
    Step 1: Choose the “To DVD” button and click "Opne/Add" button to import WMV/AVI files to convert WMV/AVI to DVD.
    Step 2: Select Merge or Batch function.
    Batch Function, Support converting multiple files to DVD VCD SVCD MPEG1/2 at the same instance
    Merge/Join function, Support selecting several clips from different sources and combine them into one single output
    Step 3: Set your preference to burn WMV/AVI to DVD.
    Step 4: Click "More Advanced Settings" button to set advanced settings for your files.
    Step 5: Choose the “Output Folder” and Click “Convert & Burn” button to start.
    Now you can enjoy your DVD and video on your portable devices and edit and burn your favorite DVD.
    Mac Video Converter
    Best DVD Converter
    Mac DVD to iPhone
