BSOD machine check exception 0x0000009c
  • BSOD machine check exception 0x0000009c
    มีใครเคยเป็นแล้วแก้ได้ไหมครับ
    0xC000009C หรือ STATUS_DEVICE_DATA_ERROR หมายความว่า มีการเรียกใช้งาน Bad Block หรือ Bad Sectors บนฮาร์ดดิสก์
    check Bad ด่วน
      check Bad ด่วน
      chkdsk ดูแล้วก็ไม่ bad นะครับ
      Code:
      Microsoft (R) Windows Debugger Version 6.10.0003.233 X86
      Copyright (c) Microsoft Corporation. All rights reserved.
      Loading Dump File [C:\WINDOWS\Minidump\Mini112408-03.dmp]
      Mini Kernel Dump File: Only registers and stack trace are available
      Symbol search path is: ************************ Invalid ************************
      * Symbol loading may be unreliable without a symbol search path.           *
      * Use .symfix to have the debugger choose a symbol path.                   *
      * After setting your symbol path, use .reload to refresh symbol locations. *
      Executable search path is:
      * Symbols can not be loaded because symbol path is not initialized. *
      * The Symbol Path can be set by:                                    *
      *   using the _NT_SYMBOL_PATH environment variable.                 *
      *   using the -y <symbol_path> argument when starting the debugger. *
      *   using .sympath and .sympath+                                    *
      Unable to load image ntoskrnl.exe, Win32 error 0n2
      ************************ WARNING: Unable to verify timestamp for ntoskrnl.exe
      ************************ ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
      Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
      Product: WinNt, suite: TerminalServer SingleUserTS
      Machine Name:
      Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
      Debug session time: Mon Nov 24 16:45:07.234 2008 (GMT+7)
      System Uptime: 0 days 4:51:35.930
      Loading Kernel Symbols
      Loading User Symbols
      Loading unloaded module list
      ************************ WARNING: Unable to verify timestamp for hal.dll
      ************************ ERROR: Module load completed but symbols could not be loaded for hal.dll
      *                        Bugcheck Analysis                                    *
      Use !analyze -v to get detailed debugging information.
      BugCheck 9C, {4, 8054e5f0, b2000000, 70f0f}
      ************************** Kernel symbols are WRONG. Please fix symbols to do analysis.
      ************************    Your debugger is not using the correct symbols                 ************************
      ************************    In order for this command to work properly, your symbol path   ************************
      ************************    must point to .pdb files that have full type information.      ************************
      ************************    Certain .pdb files (such as the public OS symbols) do not      ************************
      ************************    contain the required information.  Contact the group that      ************************
      ************************    provided you with these symbols if you need this command to    ************************
      ************************    work.                                                          ************************
      ************************    Type referenced: nt!_KPRCB                                     ************************
      Probably caused by : ntoskrnl.exe ( nt+22f43 )
      Followup: MachineOwner
      ตัวการก็ไฟล์นี้เลย
