วิวโซนิค VX2025wm 20.1" Wide Color TFT Active Matrix LCD
รายละเอียดสินค้า
LCD Panel Type 20.1" Wide Color TFT Active Matrix LCD
Display Area 17.1" horizontal x 10.7" vertical; 20.1" diagonal
Optimum Resolution 1680x1050
Contrast Ratio 800:1 (typ)
Viewing Angle 176? horizontal, 176? vertical @ contrast ratio > 10:1
Response Time 8ms gray-to-gray (avg.); 16ms white-black-white (typ)
Brightness 300 cd/m2 (typ)
Light Source Long life, 40,000 hrs. (typ)
Panel Surface Anti-glare
VIDEO INPUT Analog/Digital RGB analog (75 ohms, 0.7 Vp-p); DVI-D (TMDS, 100 ohms)
Frequency Fh: 30~82kHz, Fv: 50~75Hz
Sync H/V separated (TTL), composite, sync-on-green
COMPATIBILITY PC VGA up to 1680x1054 non-interlaced
Mac? Power Mac? G3/G4/G5 up to 1680x1050
CONNECTOR Analog/Digital 15-pin mini D-sub and DVI-D
Power 3-pin AC plug (CEE22)
POWER Voltage AC 100-240V, 50-60Hz (auto switch)
Consumption 35W (typ)
CONTROLS Basic Power, 1, down, up, 2
OnView? Auto image adjust, brightness, contrast, input select (analog, digital), ViewMatch? color adjust (sRGB, 9300K, 6500K-default, 5400K, user color - RGB), information (resolution, H. frequency, V. frequency, pixel clock, model number, serial number), manual image adjust (H. size, H. position, V. position, fine tune, sharpness), setup menu, language, resolution notice, OSD position, OSD timeout, OSD background, memory recall
POWER MANAGEMENT Meets TCO'99 and ENERGY standards
REGULATIONS UL, cUL, FCC-B, CB, CE, ENERGY STAR, NOM, NEMKO/GS (covers TUV/GS), NEMKO ERGO (covers TUV/ERGO, ISO13406-2 & MPR II), TCO99, GOST-R + 20 original copies hygienic, SASO, PCBC, VCCI, BSMI, CCC, PSB, C-TICK, Argentina-S, Green Mark, RoHS
DIMENSIONS
(WxHxD) Physical (mm) 485mm x 441mm x 201mm (with stand)
485mm x 340mm x 67mm (without stand)
Physical (in.) 19.0" x 17.3" x 7.9" (with stand)
19.0" x 13.4" x 2.6" (without stand)
OPERATING CONDITIONS Temperature 32-104?F (0-40?C)
Humidity 10-90% (non-condensing)
WEIGHT Net 13.9 lb. (6.3 kg) (with stand)
Gross 16.8 lb. (7.7 kg) (with stand)
PACKAGE CONTENTS LCD display, power cable, 15-pin VGA video cable, DVI cable, Quick Start Guide, ViewSonic Wizard CD
WARRANTY Three-year limited warranty on LCD, parts and labor
รุ่นนี้คิดว่าดีไหมครับ
แล้วประกัน อะไรพวกเนี่ย
ราคาก็ไม่แพง 12402 บาท
ท่านอื่นคิดว่าไงครับ
รายละเอียดสินค้า
DIMENSIONS
