G43Twins-FullHD
1. LGA 775 for Intel® Core™ 2 Extreme / Core™ 2 Quad / Core™ 2 Duo / Pentium® Dual Core / Celeron® Dual Core / Celeron®, supporting Penryn Quad Core Yorkfield and Dual Core Wolfdale processors
2. Solid Capacitor for CPU power
3. Intel® G43 + ICH10 Chipsets
* Supports FSB1333/1066/800MHz CPUs
* Supports Dual Channel DDR3 1066/800 (2 x DIMM slots) with max. capacity up to 4GB and Dual Channel DDR2 1066/800/667 (2 x DIMM slots) with max. capacity up to 8GB
* Intel® Graphics Media Accelerator X4500, Pixel Shader 4.0, DirectX 10, Max. shared memory 352MB
* 1 x PCI Express 2.0 x16 slot (green @ x16 mode)
* 6 x SATAII 3.0 Gb/s connectors, support NCQ, AHCI and Hot Plug functions
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and DisplayPort with ASRock DVI_DisplayPort Card
* Supports HDCP function with ASRock DVI_DisplayPort Card
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback with ASRock DVI_DisplayPort Card
* 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
* 1 x WiFi/E header
* Supports ASRock OC Tuner, I. O. T. (Intelligent Overclocking Technology)
* Supports Smart BIOS, Energy Saving Design
* Free Bundle: 1 x ASRock DVI_DisplayPort Card
* Windows® Vista™ Premium 2008 Logo Ready
* ASRock GLAN_8CH I/O: 1 x VGA Port, 6 x Ready-to-Use USB 2.0 Ports
ทำไมไม่มีฝั่ง amd เเบบนี้มั่ง
ราคา 3,290
* 1 x WiFi/E header
Graphics - Intel® Graphics Media Accelerator X4500
- Pixel Shader 4.0, DirectX 10
- Max. shared memory 352MB
- Three VGA Output options: D-Sub, DVI-D and DisplayPort with ASRock DVI_DisplayPort Card
- Supports DVI-D and DisplayPort with ASRock DVI_DisplayPort Card
- Supports HDCP function with ASRock DVI_DisplayPort Card
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback* with ASRock DVI_DisplayPort Card
*Minimum H/W requirement on 1080p playback:
Items Configurations
CPU Intel® E1200
VGA G43 onboard DX10 VGA
Memory DDR2 800 1GB x 2
OS Windows® Vista™ or Windows® Vista™ 64
Playback Software CyberLink PowerDVD8 with patch 1830U
* BIOS setup option PAVP Lite mode enabled.
CPU Intel® E1200
ราคา 3,290
