ASUS I220GC คิดว่าไง
  • ASUS I220GC คิดว่าไง
    อยากรู้ครับว่า ASUS I220GC ตัวนี้เอาไปทำอะไรได้บ้าง เห็นมันเล็กน่าซื้อดีครับ แล้ว CPU ก็กินไฟเพียง 19 W ด้วยครับ
    Specification
    CPU Integrated (FC-BGA6) Intel Celeron Processor 200 Series
    Intel® EM64T and Execute Disable Bit Technologyready
    Chipset Intel® 945GC / ICH7
    System Bus CPU FSB 533MHz ; Chipset support 533/800/1066 MHz
    Memory 2 x DIMM, for max. 4GB, DDR2 667/533MHz, non-ECC, un-buffered memory
    Dual channel memory architecture
    * Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
    **When installing total memory of 4GB capacity or more, Windows 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
    Expansion Slots 1 x PCI-E x1
    2 x PCI 2.2
    VGA Intel Graphics Media Accelerator 950
    Max. resolution:2048x1536@75Hz
    Max. UMA Memory Size 224MB
    Storage Southbridge:
    - 1 x UltraDMA 100/66
    - 4 x Serial ATA 3Gb/s
    LAN Atheros L2 10/100
    Audio Realtek ALC662, 6-CH High-Definition Audio CODEC
    USB 8 x USB2.0 ports (4 ports at mid-board, 4 ports at back panel)
    Special Features ASUS CrashFree BIOS 3
    ASUS EZ Flash 2
    ASUS MyLogo 2
    Back Panel I/O Ports 1 x PS/2 Keyboard
    1 x PS/2 Mouse
    1 x VGA
    1 x Serial port
    1 x Parallel port
    1 x LAN (RJ45) port
    4 x USB 2.0
    6 Channel Audio I/O
    Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
    1 x Floppy disk drive connector
    1 x IDE connector
    4 x SATA connectors
    1 x CPU Fan connector
    1 x Chassis Fan connector
    Front panel High Definition audio connector
    1 x S/PDIF Out connector
    Chassis Intrusion connector
    CD audio in
    24-pin ATX Power connector
    4-pin ATX 12V Power connector
    BIOS 8 Mb Flash ROM, AMI BIOS, PnP, ACPI2.0a, DMI2.0, WfM2.0, SM BIOS 2.4
    Manageability WfM 2.0, DMI 2.0, WOL by PME, WOR by PME
    Accessories 1 x UltraDMA 100/66 cable
    1 x Floppy disk drive cable
    1 x SATA cable
    1 x SATA Power cable
    I/O Shield
    User's manual
    Support Disc Drivers
    ASUS PC Probe II
    ASUS Update
    Anti-virus software
    Form Factor uATX Form Factor, 9.6"x 7.4" (24.4cm x 18.87cm)
