High-end and Luxury P45 - GIGABYTE P45T EXTREME Air-Cooling 659MHz Reached
  • High-end and Luxury P45 - GIGABYTE P45T EXTREME Air-Cooling 659MHz Reached
    In 2008, Intel launches 2 latest Chipset which are P45 and X58 plus ICH10.
    These architectures are new goal for all the motherboard manufacturers.
    “P” series always become the mid-high end products.
    As per the experience, Intel P35/45 is still the most popular products as the OC ability is easily to catch “X” series.
    GIGABYTE is always very good at Intel MB product line and separate products into DS3/DS4/DQ6 3 levels,
    the familiar model names for users buying guide by budget.
    In new P45 Chipset, GIGABYTE launched a new model is more hi-end than DQ6.
    The leading role of this test - GIGABYTE P45T EXTREME.
    For a long time, DQ6 is always the most hi-end model.
    However, after then Extreme series is the new flag ship.
    GIGABYTE P45T EXTREME Box
    New design style and pattern for EXTREME series
    Accessories
    Installation Guide, Manual, Software CD, cables, I/O panel
    GIGABYTE P45T EXTREME Body
    Left Down Corner
    1 X PCIE X1
    3 X PCIE(Blue slot run at x16 as exclusive used. When you use 3 VGA, the slots operate at x8+x8+x4)
    3 x PCI
    Realtek 8111C is LAN chip supporting Teaming technology
    Realtek ALC889A supports 7.1 channel and High Definition Audio. It also supports Dolby sound even user only use 2 channel speakers.
    PCB is MADE IN TAIWAN
    Right Down Corner
    6 x SATAII (By ICH10R)
    1 x IDE
    POWER/RESET buttons, Debug LED (the rare design in GIGABYTE products)
    Right Up Corner
    4 x DIMM DDR3, supports 800/1066/1333/1900,1900 is spec after OC
    DRAM provide extra2 phase PWM, the next by is 24-pin power connector
    CPU PWM, use 6+6 phases PWM and support DES advanced technology.
    The new VRD11.1 design guide, Intel E0 CPU will run with Intel latest energy saving technology.
    In my personal view, the 6-phase CPU PWM or support 8-phase in digital are good enough for the hi-end model.
    Ex. GIGABYTE uses 6+6-phase, DFI uses 8-phase digital.
    The entry like Biostar uses 4-phase PWM also can run Dual core and Quad core OC.
    The great benefits are power saving and environmental protection.
    IO Part
    6 X USB 2.0
    2 X RJ-45 Jack
    1 X S/PDIF
    Additional Clear COMS button
    The heat sink comes with board
    GIGABYTE always use very good quality components compares to the same price level products.
    This time uses 100% cooper thermal module which is good looking and better thermal dissipation.
    This thermal module is very beautiful design. There is another 2-phase PWM for MCH.
    For the water-block built-in module, GIGABYTE provides a special and power thermal kit - Hybird SLENT-PIPE
    100% cooper provides the best quality for thermal solution
    The Hybird SLENT-PIPE install at the PCI-e slot position.
    It also enhances the whole system thermal solution.
    (Installing Hybird SLENT-PIPE will occupy 1 PCI-e x1)
    Boot up Screen
    BIOS Main Menu
    This model puts M.I.T as the 1st position without hiding.
    It is absolutely designed for OC and performance.
    M.I.T. Page
    CPU Frequency and ratio
    Intel XMP DRAM OC technology is included
    DRAM parameters
    Providing very wide voltage range
    CPU Vcore 0.5000~2.30000V
    CPU Terminating 0.800~1.800V
    CPU PLL 1.100~2.800V
    MCH Core 0.800~1.800V
    MCH Reference 0.500~1.045V
    ICH I/O 1.000~2.300V
    DARM Voltage 1.500~2.500V
    DRAM Termination 0.7365~1.440V
      CPU/DRAM ratio meets all frequency CPU
      Advanced CPU options
      CPU Clock Skew can adjust by 50~150ps to reach higher frequency
      Advanced DRAM options also provide rich parameters
      PC Health Status
      System Configuration
      CPU: INTEL Core 2 Duo E8400/Quad Q8200
      MB: GIGABYTE P45T EXTREME
      DRAM: CORSAIR Dominator TWIN3X2048-1800C7DIN
      VGA: Gigabyte HD4870 DDR5 512MB CorssFire
      HD: Seagate 7200.10 320GB
      POWER: Corsair HX1000W Modular Power Supply
      Cooler: Thermaltake BigTyp VP/JETART Nano Diamond
      GIGABYTE also bundle many Windows applications.
      The main one is EasyTune6
      CPU info
      DDR3 info
      These 2 parts are similar to CPUZ. It is not as detail as CPUZ, but the info is enough.
      Frequency and Voltage can adjust in this software.
        Also provides VGA OC by software
        C.I.A. 2 and Smart Fan
        Voltage, Temperature and FAN speed info
        EasyTune6 integrated all necessary features and info into one software. It is very convenient.
        MB also has LED to display the DRAM voltage and PWN loading status.
        Just mention, this time I also use JETART Nano Diamond thermal pad to replace Y-500
        VGA
        Using Gigabyte HD4870 DDR5 512MB CorssFire which is the hottest VGA combo at the moment.
        Default Colck 750/1100Mhz
        3DMARK2003
        3DMARK2005
        3DMARK2006
        2008 most popular game - Crysis
        Now, the highest C/P values VGA are 4850 and 4870 for sure.
        GIGABYTE HD4870 DDR5 512MB CorssFire is really fast, especially in Crysis it has very high pages ratio even in 1920x1200
          DRAM
          Uses CORSAIR Dominator TWIN3X2048-1800C7DIN, supports XMP
          Enable XMP in BIOS, it runs 450x6,DDR3 1700 CL7 7-7-20 2.1V automatically.
          Passed SP2004 Blending XP
          CORSAIR Dominator TWIN3X2048-1800C7DIN official spec is DDR3 1800 CL7 2.0V.
          GIGABYTE has more improvement room here.
          DDR3 1933 CL7 6-5-20 EVEREST bandwidth
          The DRAM voltage and frequency after OC are mid-high standard.
          However, there is still more3% to 5% room to improve.
          P45 combo with ICH10R. I use the best stuff to see the capability of the new ICH
          SAMSUNG 64GB SSD SLC,
          market price is 700 USD. Also heard the price drops to 580 USD last week.
          EVEREST
          Tune
          This SAMSUNG 64GB SSD SLC is much faster than the MLC version, the Read/Write life cycle is also 10 times more.
          The transfer performance is really amazing.
          It takes less than 20 minutes to install the Windows XP. It is also very fast to enter the XP.
          ICH10R has its own advantage, because this SSD only reach 100Mb/s in ICH7.
          ICH10 is really improved a lot in performance.
          CPU
          Intel C2D E8400 for dual core
          I believe 99% think the stable frequency after OC is the performance standard.
          615Mhz SP2004
          Dual Super PI 32M
          This is almost the best OC capability in the all P45 boards.
          Running stable in 610~620Mhz is really amazing.
          Coming more for dual core CPU extreme OC
          644Mhz Super PI 1M
          Mostly 646~649Mhz also can enter to OS and get CPUZ certified.
          Many users use software OC to get the higher frequency for CPUZ Cert This is my first try for software OC.
          Air Cooling Dual Channel 659Mhz CPUZ Certified
          Using software can pull in the frequency for more 10~15Mhz to make the extreme OC be greater.
          However, in this condition, you cannot run any software.
          If I don’t mention it, the results are all from BIOS adjustment.)
            Q8200 for Quad Core OC
            500Mhz 4 X Super PI 32M
            530Mhz Super PI 1M
            In Quad Core CPU, it can run stable in 500Mhz and passed 1M at 530Mhz.
            It proves the P45T EXTREME is in very high standard for both dual core and quad core system.
            The Energy Saving Software from GIGABYTE-DYNAMIC ENERGY SAVER
            Later called DES. DES needs C1E to operate.
            DES disable, 2700Mhz shows 15.51W
            DES Enable, 2700Mhz shows 13.46W(4-phase)
            DES Panel provide lots of info, usage duration, power saving watts and CPU current power consumption.
            DES Disable,4050Mhz shows 80.07W(12-phase)
            DES Enable,4050Mhz shows 45.81W(8-phase)
            80.07-45.81=34.86W, the full speed power saving by DES display.
            But this is the software come with the product. I have to double check it.
            This time I use Seasonic Power Angle as the tool.
            All equipments are the same.
            DES Disable,4050Mhz system shows 339W(12-phase)
            DES Enable,4050Mhz system shows 292W(6-phase)
            The all system saving is 339-292=47W.
            It’s 35W more than the DES displayed. DES is a good prediction software.
            Strength
            1.100% Japan made solid capacitors. Full LED display under system operation. ATI CorssFireX supported
            2. Rich applications in OS. They are all powerful function and exquisite interface.
            3. BIOS provides wide voltage range and the options are never seen before in GIGABYTE products
            4. Dual Core/Quad Core CPU OC are excellent. It let CPU has 20~50Mhz possibility
            5. High cost 100% cooper thermal modules. It is hard to see in the other brands boards
            6. Debug LED, Power/Reset/Clear CMOS buttons
            7.6+6-phase dynamic power saving with Intel latest VRD11.1 PWM design. It combines very well with own DES software for lower power consumption
            Weakness
            1. The cables are too less. The cables are enough but should be more for hi-end products
            2. DRAM voltage is higher than other brands. Also hope the future BIOS can support over DDR3-2000.
            3. Clear CMOS battery is under the cooper pipe. Not easy to use.
            Performance ★★★★★★★★★☆
            Components ★★★★★★★★★★
            Outlook ★★★★★★★★★☆
            C/P ★★★★★★★☆☆☆
            GIGABYTE EXTREME series is really for Enthusiasts.
            For the scoring system, I am always very strict for it.
            This is the 1st product I ever score 10 stars.
            It is because GIGABYTE really puts a lot of effort in components.
            7 stars in C/P, because 330USD price is too high even with very great OC and components.
            The hi-end board C/P is always very low. It’s coming with DDR3, so I minus 1 star from 8 to 7.
            I’ve been testing many P45 boards, the good OC board should run stable at dual core 600Mhz and quad core 500Mhz.
            DRAM must reach DDR2 1200 and DDR3 1800 CL7.
            The 9 stars are scored by this standard.
            I still have to mention, I hope P45T EXTREME DDR3 OC ability can be improved by future fine tuning BIOS to reach 2000.
            No matter what product range, 330USD is still also very high C/P value with GIGABYTE P45T EXTREME.
            Mid-end P45 has Biostar which are between 130~160 USD and hi-end OC P45 has GIGABYTE P45T EXTREME.
            If you cannot find any points to upgrade from P35 to P45, you can wait and see for awhile.
            However, for personal view, the P45 runs stable at 600MHz is improved quite much than P35 in OC capability.
            GIGABYTE launched P45T EXTREME(DDR3) and P45 EXTREME(DDR2) make the more choices for Enthusiast market.
            Windwithme reviews all take much time and effort.
            Normally, it takes1 to 3 weeks to complete the article.
            If you think my review is good for product info and buying guide, please reply my post.
            Your reply push me go forward. Thanks….
              เอาเรื่องแฮะ
                แรงครับ
                ประหยัดไฟได้ตอน OC ด้วย ไม่เลวเลย
                  โหด
                    มีลูกปัดด้วย สงสัยกลัวไม่ luxury - -
