อยากได้รายละเอียด Mainboard ASUS P5GD2 DX อ่ะครับ
Specification
CPU LGA775 socket for Intel® Pentium 4/Celeron CPU
Compatible with Intel® 04B and 04A processors
Intel® Hyper-Threading Technology ready
Support Intel EM64T and EIST technology
Chipset Intel® 915P
Intel® ICH6R
Front Side Bus 800 / 533 MHz
Memory Dual channel memory architecture
4 x 240-pin DIMM sockets support max. 4GB DDR2 533/400 non-ECC memory
Expansion Slots 1 x PCI Express x16 slot for discrete graphics card
3 x PCI Express x1
3 x PCI
Storage/RAID Intel® ICH6R South Bridge:
*1 x UltraDMA 100/66/33
*4 x Serial ATA with IntelR Matrix Storage Technology with RAID 0, 1 support
Silicon Image® RAID controller:
*4 x Serial ATA with JBOD, RAID 0, 1, 10, 5 (RAID 5 software patch available, no WHQL)
ITE IDE RAID controller:
* 2 x UltraDMA 133/100/66 with JBOD, RAID 0, 1, 0+1 support
LAN Marvell® 88E8053 PCI-E Gigabit LAN Controller, features AI NET2
Wireless LAN 54 Mbps IEEE 802.11g and backwards compatible with 11 Mbps 802.11b
*Access Point function (under WinXP, 2003)
*Bundle an external antenna
*One-touch wizard
*Wireless bridge, a.k.a. WDS or wireless repeater (under WinXP, 2003)
Audio C-Media High Definition Audio 8-channel CODEC
Coaxial, Optical S/PDIF out on back I/O port
Features Dolby® Digital Live technology
IEEE 1394 TI 1394 controller supports 2 x 1394 ports
USB Max. 8 USB2.0 ports
ASUS AI Proactive Features AI NOS™ (Non-delay Overclocking System)
AI NET2 network diagnosis before entering OS
WiFi-g™ powered by WiFi@HOME? technology
Stack Cool™ patented fanless cooling system
Overclocking Features AI NOS™ (Non-delay Overclocking System)
AI Overclocking (intelligent CPU frequency tuner)
CPU, Memory, and PCIe x16 voltage adjustable
SFS (Stepless Frequency Selection) from 100MHz up to 400MHz at 1MHz increment
Adjustable FSB/DDR ratio. Fixed PCI/PCIe frequencies.
ASUS AI Booster utility
ASUS C.P.R.(CPU Parameter Recall)
Other ASUS Special Features CrashFree BIOS 2
Q-Fan2
Post Reporter
Multi-language BIOS
MyLogo2
BIOS 8 Mb Flash ROM,AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3
Back Panel I/O Ports 1 x Parallel
1 x WLAN antenna jack (optional)
1 x Optical + 1 x Coaxial S/PDIF Output
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x RJ45
4 x USB 2.0/1.1
1 x IEEE1394a
8-Channel Audio I/O
Internal I/O Connectors 2 x USB 2.0 connectors supports additional 4 USB 2.0 ports
1 x LAN connector
1 x IEEE1394 connectors
1 x COM connector
1 x GAME/MIDI connector
CPU / 2 x Chassis / Power Fan connectors
Front panel High Definition Audio connector
Chassis Intrusion connector
CD audio-in connector
24-pin ATX Power connector
4-pin ATX 12V Power connector
Support CD Drivers
ASUS PC Probe
ASUS LiveUpdate Utility
Anti-virus software (OEM version)
Accessories InterVideo® WinDVD Suite (OEM version)
1 x Wireless LAN antenna (optional)
1 x IEEE1394 port
6 x Serial ATA cables
3 x 2-port SATA power cable
1 x 2-port USB2.0 / Game module
1 x COM Port module
2 x UltraDMA 133/100/66 cable
1 x IDE cable
1 x FDD cable
1 x I/O Shield
User's manual
Form Factor ATX Form Factor, 12" x 9.6" (30.5cm x 24.5cm)
รับไม่ได้งับOriginally posted by Alexandrite View Postรองรับ Quad Core มั้ยครับ
Chipset Intel® 915P
Intel® ICH6R
Quad Core มัน 1066MHz งับ
คือบังเอิญผมจะซื้อเครื่อง Server ไว้ทำเว็บด้วย เลยเล็งของ Intel ดูน่ะ
ASUS "P5B-E" Intel P965 Chipset Mainboard for Intel LGA 775 CPU Retail
57750 บาท
Specifications
Supported CPU: Intel® Quad-core CPU Ready LGA775 socket for Intel® Core™2 Extreme / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Processors
Chipset: Intel P965 + Intel ICH8R w/ Intel Fast Memory Access Technology
FSB: 1066/800/533MHz
Memory: 4x 240pin Dual Channel DDR2 800 Max 8GB
Slots: 1x PCI Express X16, 3x PCI Express X1, 3x PCI
Ports: 2x PS/2, 1x LPT, 10x USB2.0 (Rear 4), 2x IEEE 1394a (Rear 1), 1x eSATA, 1x RJ45, S/PDIF Out, Audio Ports
IDE: 1x ATA 133/100 up to 2 Devices
SATA: 6x SATA 3.0Gb/s w/ RAID 0/1/5/10
Additional Controller: JMB363
Onboard Audio: ADI 8-channel High Definition Audio CODEC
Onboard LAN: Attansic L1 10/100/1000Mbps
Form Factor: ATX
Warranty: 3 Years
Packaging: Retail
