9800 GX2 SLI ต้องใช้ PSU เท่าไร่ครับ
* A single GeForce 9800 GX2 requires you to have a 550 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total) at least 35 Amps available on the 12 volts rails.
* A second GeForce 9800 GX2 installed is another ballgame though; on this system it requires you to have a 750 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total) at least 45 Amps available on the 12 volts rails.
