ขึ้นจอฟ้าแบบนี้ ปัญหาอยู่ตรงไหนอ่ะครับ ขอบคุณคับ
A problem has been detected and windows has been shut down to prevent damage to your computer.
The problem seems to be caused by the following file: Ntfs.sys
PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time you're seen this stop error screen,
estart your computer. It this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical information :
****** STOP : 0x00000050 (0xE0609D9C, 0x00000000, 0xBA60B6ED, 0x00000000)
****** Ntfs.sys - Aderss BA60B6ED base at BA5EB000, DateStamp 45cc56a7
select Safe Mode.
