พอดี ผม จะลง วินโดว xp แต่พอรันไปได้สักพัก ขึ้น ข้อความนี้ งงเป็น บ้าแล้วครับ ช่วยด้วย
A problem has been detected and windows has been shut down to prevent damage to your computer
if this is the first time you"ve seen this stop error screen
restart your comprter. If this screen appers again, follow
these steps:
The BIOS in this system is nut fully ACPI compliant. Please contact your
system vendor or vist http://www.hardware-update.com for an updated BIOS
If you are unable to obtain an update BIOS or the latest BIOS supplied by
your bendor is nut ACPI compliant, you can turn off ACPI mode during text
mode set up. To do this, Simply press the F7 key when you are prompted to was pressed = it will silently disable acpi nad allow you to contimue
your installation
Technical information:
****** Stop: 0x000000A5 (0x00000007.0xF799FF21,0x20061109)
these steps:
your installation
