กลุ้มใจ งานเข้า เนื่องจากงาน Commart
  • #31
    hp w1907v ใช้รุ่นเดียวกันเลยงับ ของผมไม่มี DVI เหมือนกัน แง มันไม่ใส่มาให้อะ มีแค่ช่อง
    สงสัยใส่กะรุ่นสูงกว่านี้แหง หรือว่าเค้าโกงผมแว้ว เซ็งเป็ด
    Display information
    Display size
    19" (48.3 cm) diagonal and viewable image - 41.0 cm x 25.6 cm (WxH)
    Display type
    Wide Thin Film Transistor Liquid Crystal Display active matrix
    Refresh response time
    5ms (rise + fall)
    Display brightness
    300 cd/m2 (typical)
    Contrast ratio
    1000:1 (typical)
    Video input connector
    Analog (15-pin miniature D-sub VGA)
    Speakers and microphone
    Integrated active speakers (2 x 2W /channel) with front volume control
    Display viewing angle
    160 degrees horizontal and 160 degrees vertical viewing angle (10:1 minimum contrast ratio)
    Display moving angle
    Swivel and vertical tilt range -5 degrees to 25 degrees; standard 4 hole pattern 100mm x 100mm screw wall-mounting option
    Display resolution
    1440 x 900 @ 60Hz max
    Horizontal scan rates
    55-75Hz vertical, 30-83kHz horizontal
    Plug and play
    Faceplate treatment
    HP BrightView Technology
    Display, maximum pixel rate
    136.7 MHz in 1440x900 at 60Hz
    Physical security
    Kensington lock ready
    User controls
    Brightness, Contrast, Image Control, Color, Quick View, Language, Management, Information, Factory Reset, Exit, 8 Languages
    Box content
    Monitor, AC power cord (1.9 m), VGA video cable (1.8 m), audio cable, documentation CD, and Limited Warranty Card
    Power
    Power supply type
    External AC 100-240V, auto-ranging, 50-60Hz
    Power consumption
    49 watts maximum on operating mode; 2 watts max in power saving mode
    Dimensions / weight / warranty
    Dimensions, metric (W x D x H) with stand
    462 x 380 x 184 mm
    Weight
    5.0 kg
    Warranty statement
    Limited one-year part and repair labour warranty (certain restrictions and exclusions apply)
    Other information
    Compliance industry standards
    CE Marking, 9241-3,7,8 VDT guidelines, ISO 13406-2 pixel defect guidelines, MPR-II, FCC approval, Microsoft Windows certified (Microsoft Windows 2000, Microsoft Windows XP, and Microsoft Vista), UL listed, GOST (Russia), SASO (Saudi Arabia), SABS (South Africa), SEMKO
    Operating temperature range
    0° C to 40° C, 15%-90% relative humidity non-condensing
    • #32
      โดนซะแล้วละครับพวกร้านมันชอบเขียนมั่ว - - เราต้องดู spec ผ่านทางเว็ปหลักๆหรือข้า่งกล่องเลยอะครับ
      เคยเจอ notebook เขียนแรม 1 G พอแอบไปคลิกดูในคอม มี 512 - -'' เดินออกเลย
      • #33
        ยังใช้ crt อยู่
        • #34
          ตุกติกนี่หว่าเเบบนี้ ทวงครับ ถ้าใม่ให้ก็ปาเงินใส่ร้านบอกมีเงินซื้อใหม่ก็ได้ ^ ^
          • #35
            ยินดีด้วยครับ ได้จอ wide 22" มาใช้ จะบอกว่ามันแจ่มจริงๆ
            ใช้จอ Dell 2208WFP อยู่แจ่มเ่ช่นกัน อิอิ
            • #36
              เค้าให้เปลี่ยนแล้ว คับ ดูรุ่น 943BWX ของซัมซุงคับ แต่เช็คราคาในฮาดแว์เฮ้า ราคาตั้ง 8090 แหนะคับ
              ผมเช็คราคาเสิท ตามกูเกิ้ล บางที่ 5800 บางที 6xxx เท่านั้นเอง ทำไม ร้านมันขายโหดงี่ รุ่นนี่มันราคาเท่า
              ไหรแน่ไม่ทราบคับ โคตรจะโหดเลยคับถ้าราคาต่างกันแบบนั้น รู้สึกเสียเปรียบอย่างแรง เพราะเค้าไม่ คืนส่วนต่าง
              เป็นเงินให้ แต่เป็นของอย่างอื่นในร้านแทน เพราะถอยจอมา 8,400
              คิดว่าจะเปลี่ยนเป้นรุ่น 943BWX ดีไหมคับ
              • #37
                Originally posted by tonzakung View Post
                อิจฉาคนกรุงเทพจัง มีของถูกๆใช้
                เช่นกัน
                ตอบเจ้าของกระทู้
                เอาบิลไปรับเลยก็ดีครับ
                • #38
                  ผมเคยลองต่อสองแบบดู ตาผมแยกไม่ออกนะ d-sub กับ dvi - -"
                  • #39
                    ผมซื้อ 2232GW เมื่อต้นปีนี้ มันก็แถมมาให้นะครับ ทั้ง DVI และก็ D-Sub
                    เลยใช้ DVI ไป
                    ปล.สาย DVI ที่แถมมาหัวมันเปนสีขาว มันต่างจากสาย DVI สีดำที่ขายตามร้านทั่ว ๆ ไปมั๊ยครับ ?
                    • #40
                      or = หรือ...อย่างใดอย่างหนึ่ง
                      and = และ...รวมด้วย
                      หยิบผิดตัว ผิดรุ่นแยกย่อยแล้วละมั๊งครับ อิอิอิอิ
                      • #41
                        Benq ไม่แถมทุกรุ้นเน้ออออ
                        ของผมมันเขียน dvi เปน optional
                        • #42
                          Originally posted by beersonic View Post
                          สาย DVI ดีๆ มันแพงนะค้าบ ถ้าจำไม่ผิดเส้นละเป็นพันเลย
                          เส้นละเป็นพัน มันสาย HDMI ม่ะใช้เหรอคับ ท่าน DVI ราคาไม่แพงขนาดนั้นนนน น่ะคับ
                          • #43
                            แปลกแฮะ คนถามกันทั้งกระทู้ว่ารุ่นไหน ทำไมไม่ยอมบอกล่ะ มีเหตุผลอะไรหรอครับ เห็นก็มาตอบกระทู้เรื่อยๆ -*-
                            • #44
                              ราคา หกพันกว่าๆ(ปลายๆ)
                              น่าจะเป็น G2210W เป็นรุ่น21.6" มั่งครับ (เป็นรุ่นลดขนาดจุดให้เล็กลงจาก 0.282 เป็น 0.276)
                              ค่าความละเอียดจอเท่ากับ 22" 1680X1050
                              ราคาน่าสนใจ เดินๆดูอยู่เหมือนกัน
                              ถ้าไม่ติดที่ไม่ชอบกรอบเงาๆ(มันสะท้อนแสงเวลาเล่น) คงสอยไปแล้วเหมือนกัน
                              • #45
                                ไหง benq เรา FP202W ถึงมีให้หวา แต่ซื้อตั้งแต่ออกใหม่ๆ ราคา 15,900 เลย ว่าจะเปลี่ยนไปใช้ 24 แบบ clear bright ซะหน่อย ยังไม่เจอถูกใจ 22 ก็ได้ resolution เท่าเดิม (1680x1050) เลยไม่รู้จะเปลี่ยนไปทำไม = =
