What is a central VAC system and is it the right one for you
  • What is a central VAC system and is it the right one for you
    Having a clean house and a refreshing atmosphere is always the ideal environment for every household, which is why we always try our best to make our houses as clean as possible by having them vacuumed frequently.
    ➜➜➜ See It Here: Best Rated Vacuum Cleaners
    Having said that, in this post, we’ll be taking a look at the central vacuum system, which is often considered one of the most complete and effective cleaning systems for your house. Find out what it is and if you really need it with our experts’ opinions from thekinglive.com.
    What is a central VAC system?
    Generally speaking, a central VAC system is like a giant canister vacuum cleaner with a powerful suction unit and multiple hoses that reach all the different places in your house. The hoses are then installed to the inside of your walling system, leaving only a small outlet for you to plug in the hose.
    As a result, you can easily vacuum the different areas around your house without having to carry a large canister or upright vacuum cleaner around. Instead, you just need to bring along your plastic hose and a few attachments, if needed.
    In addition, the central VAC also comes with a much larger dust container compared to other canister or upright models. Hence, you won’t have to empty your dustbin very often.
    ⫸⫸⫸ Check Over Here: Best Vacuum Cleaners On The Market - TOP Rated Best Vacuum Cleaners Reviews
    Is it the right vacuum for you?
    Now that you know what it is, it’s time to decide whether the central vacuum is good for you:
    Why you should choose it
    Powerful suction with good capacity
    Compared to your average vacuum cleaner, a central VAC system can generate a much more powerful suction. This is mostly thanks to the robust motors that come with it. Plus, by having the vacuum installed on your walling system, it can draw much more electric power compared to using the power outlet.
    Plus, by having a large dust container, your central VAC system will require less dumping, which will save you a lot of work.
    Usually comes with maintenance support
    Speaking of which, if you have the central vacuum installed by your contractor or any other company, you won’t likely have to do the dumping yourself. Instead, there will be technical support to help you with that, along with regular maintenance.
    Easy to use and flexible
    As we’ve mentioned, to use the vacuum, you just simply have to open the outlet to activate the vacuum and plug in your hose to start cleaning. Once you’ve done, just remove the hose, close the outlet, and move to another room with another outlet ready for you.
    This is as simple and flexible as vacuuming could ever get. If you’re not very keen on carrying your large canister vacuum with you all the time, we really recommend you having a central VAC system installed.
    Cleaner house and atmosphere
    With the central vacuum, all the air will be released outside of your house, so the chance of re-dispensing the dust into the air like canister or upright vacuums is almost zero. Hence, you’ll have a fresher and more comfortable atmosphere.
    ➽➽➽ Further Reading: Best vacuum cleaner for home
    Why you shouldn’t choose it
    Expensive
    One of the most common reasons why people refuse to choose these systems is because of their price, which is not very cheap, even with the lowest models.
    Excessive power
    Not all of us would likely need these powerful vacuums for our houses, especially when you only live in a small house without many rooms.
    And that’s our thoughts on this matter. We hope you find them useful when it comes to choosing the right vacuum cleaner for your home.
    แบบนี้ลองเช็คทีละจุดดูครับ
    ถอดอุปกรณ์ต่อพ่วงทั้งหมดออก ถ้า MB ใช้การ์ดจอออนบอร์ดได้ ก็ให้เหลือแค่ RAM 1 แถว ไดร์ฟที่ใช้บูตระบบก็พอ
    แล้วลองทำวนไปเรื่อยๆ ถ้าทุกอย่างผ่าน ให้ลองใส่อุปกรณ์อื่นๆ กลับเข้าไปทีละตัวแล้วลองดูอีกที
    MB อัพเดตไบออสล่าสุดรึยัง บางทีมันก็มีส่วนด้วยเหมือนกันเพราะเวอร์ชั่นที่ออกใหม่ๆ ส่วนมากจะแก้ปัญหาต่างๆ ที่พบ (ส่วนน้อยจริงที่มักใช้ของใหม่แล้วเจอปัญหาต้องโรลแบ๊คกลับไปเวอร์ชั่นก่อนหน้า)
      เจออาการคล้าย ๆ กันนี้กับเครื่องที่ใช้ psu plenty 500W
      โดยสเปคไม่ได้กินไฟมาก แต่เหมือนมีปัญหาแฝงใน psu
      หลายครั้งดับเครื่องไปแล้วต้องรอหลายสิบนาที จึงจะเปิดเครื่องติด
      เปลี่ยน psu แล้วหายสนิท
      ลองหา psu มาเทสดูครับ อาการเปิดไม่ติด ไม่น่าเกี่ยวกับไฟพอหรือไม่พอ
      ลองดูว่าพัดลม psu ทำงานปกติด้วยไหม
      หรือแกะ psu มาทำความสะอาด ล้างแผงวงจรได้ด้วยก็ดี
        สังกะสัย Asrock H87M...ป่วย พาไปหาหมอ
          มี asus h81m-d+ i5 4570 อยู่ตัวนึง ใช้กับ psu ocz ตัวไหนสักตัว หลายปีมากละ บูทหน้าวินโดว หมุนๆ ตอนแรก นานเว่ออ // พอเปลี่ยนมาเป็น corsair vs450 ตัวใหม่ หายเลยยย
            H81 พึ่งแต๊บไปวันนี้เช่นกัน (หนูฉี่ใส่)
