ใครใช้ EK Supreme HF (หรือกำลังจะซื้อ) ชุดน็อตยึดเปลี่ยนใหม่แล้วนะครับ
  • ใครใช้ EK Supreme HF (หรือกำลังจะซื้อ) ชุดน็อตยึดเปลี่ยนใหม่แล้วนะครับ
    มีขายแยก เฉพาะชุดน็อตด้วย
    Product Description & Info
    New mounting mechanism for best performing CPU waterblocks in the world.
    Mounting mechanism is being sold without block, thermal paste or fittings. For these items please search in our web shop.
    Product Description
    EK has developed a new mounting mechanism, thus removing only disadvantage of Supreme HF block and turning it into its advantage.
    New mounting mechanism offers easy to install procedure, with better grip on thumb nuts and more overall stability.
    Each of springs offer 7,8 kg of pressure, therefore optimal pressure of 30 kg on CPU can be achieved.
    All thumb nuts and screws are nickel plated.
    Package contains:
    - 4 M4 polyamide washers (0,5mm thick)
    - 4 metal M4 washers
    - 4 thumb nut CPU M4
    - 4 M4x14 DIN965 screws
    - 4 thumb screw CPU M4
    - 4 springs M4x16mm
    Made in Slovenia - EU!
    $12.50 = 378 บาท (ราคาไซไวเดอร์)
    EK-Supreme HF mounting mechanism update - 22/03/2011
    Since it’s debut the award winning EK-Supreme HF water block, the main object of criticism was it’s mounting mechanism. Therefore we have developed a new mounting mechanism to match blocks quality and design.
    We will name the water block EK-Supreme HF “easy mount”. This will be only way to indentify the new water block, as the packaging, apart from the label sticker, will not differ from it’s predecessor. Moreover, the EAN# number will remain the same.
    There are two changes made to the EK-Supreme HF easy mount delivery:
    New “easy mount” mounting mechanism replacing the old mounting system
    Extra jet plates will NOT be enclosed in the delivery any more (these will still be available to purchase separately). EK-Supreme HF easy mount will be equipped with jet plate #1, which has proven to be best performer.
    EK will start shipping all EK Supreme HF easy mount water blocks with new mounting mechanism as of March 22nd.
    เมพ ขิงๆ
    น่าหามาใช้
      ดูแล้วเหมือนกับว่ามันคลุมชุดสปริงใว้หมดเลย ขนาดเลยใหญ่พอๆกับ3/8 อิอิ
        มีคนนำมาขายไหมครับ ทำไมมันสวยงามมากมายเลย อิอิ
          เทพขึ้นเป็นกอง เสี่ยเอก เสี่ยบิว จัดไป อย่าให้เสีย
            ราคาถึงเมืองไทยแค่ 400 บาทเองครับ ของใหม่มาเต็มครับ แต่ไม่มีเวลามาอัพเดทข่าวครับ
              เสียตังกันอีกแล้วครับงานนี้
                หล่อขึ้นเป็นกอง เด๋วกลับมาเล่นละไม่พลาดเเน่ อิอิ
                  เอามาโมใส่ rasa ดีมั๊ยเนี่ย
                  งามอีหลี ^^
