ตามรูปนี้ครับ อยากได้แบบไม่ใช้หม้อ กับพัดลม ถ้าไม่มีก็ตามรูปถัดไปครับ
รูปและรายละเอียดเพิ่มเติม http://www.quietpc.com/gb-en-gbp/pro.../reserator1-v2
The Thermaltake Rocket (foreground) is a completely fan-less water-cooling system for CPUs. The Rocket makes use of its tower design as immensely large radiator. Its CPU water block is compatible with all CPU types like Silent Water.
If that's not hardcore enough, you might want to look out for the Thermaltake Symphony, which is also an external liquid cooling system, but its radiator is much larger than that of the Rocket and utilizes multiple low-speed fans for forced heat dissipation. The actual product will have a front grill to mask the internals away and that would 'transform' it into a flat panel speaker tower. You might want to get a pair of Symphony towers to complete your 'stereo system'.
ที่มา http://www.hardwarezone.com.au/revie...19&cid=13&pg=6
