Asus Rampage II Extreme
[IMG]http://www.overclockzone.com/strangers/year2008/11/asus_riie/2.jpg[/IMG]
XSPC RX Series Radiators
XSPC RX480 - 4x120mm Radiator Rev. 2
Introducing the RX480, the highest performing radiator XSPC have ever released. At close to twice the thickness of the RS series radiators it has excellent cooling capabilities and the sub 8fpi gives the radiator very low air flow resistance. The RX480 has been designed and optimized for low speed fans so it can offer high performance cooling at very low noise levels.
- Black Matt Finish
- Copper Tubes and Fins
- 3 rows of 13mm by 2mm Tubes
- Sub 8fpi (fins per inch)
- G1/4" Ports
- 6-32 Case and Fan Screws
Supplied with mounting screws
Acrylic Dual 5.25 Reservoir
for Laing D5
- Supports one Laing D5 pump
- G1/4" Thread
- Dimensions: 149 x 96.5 x 85.5mm
- Removable Brushed Aluminium Faceplates
- High Quality Acrylic
- Brass screw threads with anti-vibration mounts
- 2x 5mm LED holes
- Individually pressure tested
Supplied with black and silver faceplates, screws, allen key, and blue LED.
จัดหาอุปกรณ์จากท่าน ekkarin [IMG]
PSU
Toughpower 1200W Cable Management
ขาด Block Ram Cooler หามาให้ที 55""
xspc 480tx 4250
xspc 665 Bay 45 2200
Feser Rotary 45 500
Bitspower Stop 150
Pulse Stand 1350
EK - 250 1300
Lian Li PC-8FIR Advanced Mid Tower Case - Red Spider Edition
