XtraFlo
(R4-XFBL-22PR-R1)
Specifications
Dimension 120 x 120 x 25mm
Speed (R.P.M.) 800 - 2200 R.P.M ± 10%(PWM)
Air Flow (CFM) 34.02 – 93.74 CFM ± 10%
Air pressure (mmH2O) 0.43 – 3.30 mmH20
Noise 15 - 38 dBA
Bearing Type DynaLoopTM Bearing
Fan Life Expectancy 40,000 hours
Voltage 12V DC
Current (Ampere) 0.45A (0.7A MAX)
Power consumption 5.4W (8.4W MAX)
Weight 102 g
Connector 4-pin
Accessory Rubber screws x 4
Metal screw x 4
Rubber pad x 4
Molex-to 3-pin adapter x 1
