Model Name: Ninja3 CPU Cooler Model No.: SCNJ-3000 manufacturer: Scythe Co., Ltd. Japan Heatsink Dimensions: 120 x 120 x 160mm 4.72 x 4.72 x 6.30 in Material of Base Plate: Nicel-Plated Copper Fan Slip Stream 120 PWM Adjustable Dimensions: 120 x 120 x 25mm 4.72 x 4.72 x 0.98 in Speed: Max. Band 740 (±25%) - 1,900rpm (±10%)
Min. Band 470 (±30%) - 1,340rpm (±10%)
Noise Level: Max. Band 9.8 - 37.0 dBA
Min. Band 7.05 - 27.3 dBA
Air Flow: Max. Band 37.15 - 110.31 CFM = 63 - 187?/h
Min. Band 23.0 - 76.53 CFM = 39 - 130?/h
Bearing Type: Sleeve Bearing Weight Included Fan: 1040g
36.38 oz Compatibitliy Intel®LGA1366 Professor
Intel® Xeon® 3500 Series
Intel®Core™ i7Processor Extreme Edition Series
Intel®Core™ i7Processor 9xx Series
Intel®LGA1156 Professor
Intel® Xeon® 3400 Series
Intel®Core™ i7Processor Series
Intel®Core™ i5Processor Series
Intel®Core™ i3Processor Series
Intel®LGA775 Professor
Quad-Core Intel® Xeon® Processor 3200 Series
Dual-Core Intel® Xeon® Processor 3000 Series
Intel®Core™ 2 Extreme Processor
Intel®Core™ 2 Quad Processor
Intel®Core™ 2 Duo Processor
Intel®Core™ Duo Processor
Intel®Premium® Processor Extreme Edition
Intel®Premium® D Processor
Intel®Premium® 4 Processor Extreme Edition Supporting Hyper-
Threading Technology
Intel®Premium® 4 Processor Supporting Hyper-threading Technology
Intel®Celeron® D Processor
AMD Socket AM3 Processor
AMD Phenom™ II X4 Processor
AMD Phenom™ II X3 Processor
AMD Phenom™ II X2 Processor
AMD Athlon™ II X4 Processor
AMD Athlon™ II X3 Processor
AMD Athlon™ II X2 Processor
AMD Sempron™ Processor
AMD Socket AM2+ Processor
AMD Phenom™ X4 Processor
AMD Phenom™ X3 Processor
AMD Athlon™ X2 Processor
AMD Socket AM2 Processor
AMD Athlon™ FX Processor
AMD Athlon™ Processor
AMD Socket940 Processor
AMD Socket939 Processor
AMD Socket754 Processor
M.A.P.S. (Multiple Airflow Pass-through Structure)
The developed M.A.P.S. (Multiple Airflow pass-through structure) is a completely
new fin structure, where the airflow generated by the Scythe Slip Stream 120
PWM Adjustable fan. Ninja 3 fanless performance could be improved up to 7%
compare to the former model by using the M.A.P.S. in combination with eight
heatpipe high-performance design.
F.M.S.B.2 (Flip Mount Super Back-Plate 2)
Improved version of F.M.S.B (Flip Mount Super Back-Plate), the compatibility has
been maximized as well as achieving the solid mounting of the cooler onto the
motherboard. Scythe Ninja 3 provides broad socket compatibilities for AMD &
Intel platform.
Slip Stream 120 mm PWM Adjustable
Equipped with Scythe original Slip Stream PWM 120mm PWM Adjustable fan, it allows a user to choose the fully automatic PWM feature fan speed control or alternatively adjust the PWM band range to fulfill demands from silent to high performance users!
**PCI Branket Installation: Please remove the knob attached to the fan controller before installing into the PCI bracket. After the installation, please attach back the knob.
คิดว่า บอร์ด จะ หัก ไหม
แล้ว ถ้า ใส่พัดลม 4 ตัว จะดังกว่า โรงสีไหม
ถ้า มีของ มาไทย แล้ว จะเอา มาให้ ชม กัน
